R&V and DIRT RIOT JUNE 9TH 2012 - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Trail Rides & 4x4 Events
Old April 12th, 2012, 09:32 AM   #61
Cool parts peddler
Ironman Offroad's Avatar
Originally Posted by ronprice View Post
Vendor spots avail Now.
Check is in the mail!
Old April 12th, 2012, 09:36 AM   #62
jimhri
jimhri's Avatar
is it DIRT ROIT or DETROIT ROIT?
jimhri is offline   Reply With Quote
Old April 12th, 2012, 06:47 PM   #63
ronprice
ronprice's Avatar
Thank you Sir:
ronprice is offline   Reply With Quote
Old April 13th, 2012, 09:24 AM   #64
choppergar
choppergar's Avatar
choppergar is offline   Reply With Quote
Old April 20th, 2012, 09:07 AM   #65
ronprice
ronprice's Avatar
Getting closer. The races out west are quite open land. It will be fun to watch them in the trees.
Old May 6th, 2012, 05:29 PM   #66
ronprice
ronprice's Avatar
ONE MONTH TO GO.
Who has signed up
http://www.werocklive.com/events/eve...great-lakes-1/
Old May 7th, 2012, 06:44 PM   #67
Cool parts peddler
We need some stock trail and modified trail class rigs for this event!
Limited sponsorships available for as yet UNREGISTERED Rigs from IMOR.
PM us for details.
Any other dealers stepping up?
Old May 7th, 2012, 08:43 PM   #68
chevotass
chevotass's Avatar
im shooting for the trail class. working hard to have rig done in time.
Old May 7th, 2012, 09:55 PM   #69
barbarian 4x4
Old Guys Rule
barbarian 4x4's Avatar
need a co-driver ?
barbarian 4x4 is offline   Reply With Quote
Old May 8th, 2012, 05:54 PM   #70
ronprice
ronprice's Avatar
PM us for details.
Thanks Dale.
Sponsored entries can be great for both promoter and racer.
Old May 12th, 2012, 08:04 AM   #71
Ron,
So what will the spectator availability be like? Can we get to some of the good locations? Do we need to be there before the race and stay there till after the race or can we move around at all? All high speed or some bottle necks too?
Trying to figure out if it's worth a day's drive to spectate.
Old May 12th, 2012, 08:55 AM   #72
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
I need a sponcer......
Old May 12th, 2012, 09:02 AM   #73
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Ron,
this
H.o.r.e
Old May 12th, 2012, 10:31 PM   #74
NightKrawler
KOH Jackhammer
NightKrawler's Avatar
Here are some rules copied from Pirate from a post from Big Rich. The post is from 12-16-11, so not sure if it's still up to date. I've tried registering for the Dirt Riot forum to ask the right questions and hopefully get the right answers, but no luck.
This is all I can come up with for now:
Dirt Riot Trail Class Rules
These rules are intended to promote a safe and fair racing environment, these classes are open ended in many aspects due in large part to allow as many already built trail rigs to compete with a minimum amount of changes. Changes to these rules may occur at anytime during the racing season, rules changes will be posted on the follow websites; werocklive.com, W.E.Rock Events facebook page, pirate4x4.com, direct contact with competitors may occur but is not guaranteed.
Stock Trail
1. Frame must be stock full frame (exception, when bobbing the rear then only can a minimum amount of frame be removed, equal to the amount of body removed), with all cross members (exception, frt. Cross member with changing to a straight axle).
2. Suspension type must remain the same as OE, per vehicle production year, make and model.
3. Any axle up-grade is allowed
4. No tire greater than 37” by sidewall listing or metric equivalent
5. Full body vehicles only, bobbing is allowed between rear axle and rear bumper, but at least 24” must remain from centerline of axle to rear of bumper, no dovetailing or boat siding allowed
6. No cutting of floor is allowed with the following exemptions. The center section of the floor is approved for cutting & rising to allow drive train clearance directly over drive train components. This does not include Drivelines, axles or axle shafts. Cutting and re-boxing for the clearance of non-suspension items, including tires, shocks and fuel tank is permitted. No boxing for clearance of springs, air-shocks, or suspension links is allowed.
Modified Trail
1. Must have body panels including hood when starting the race
2. Any suspension mod’s allowed
3. Stock or round tube chassis’s are acceptable
Both Classes
1. No By-pass type shocks allowed in mod trial, coil-over shocks are acceptable
2. 6 point cage of acceptable design and configuration, must be at least 1.5” .120 wall or greater and magnetic steel material
3. Minimum of 4 point harnesses must be used for both driver and co-driver; they must be in good shape and show no signs of wear or weather damage, condition to be decided by a Dirt riot “Official”
4. Side protection/Door bars required
5. Front mounted winch with synthetic winch line highly recommended
6. Solid roof required, magnetic metal of at least .040 or aluminum of 1/8” in thickness acceptable
7. Complete floorboard and firewall required, firewall must extend from inner side panel to opposite inner side panel, and from floorboard to engine hood.
8. Fuel cell/gas tank must be separated from passenger compartment. Fuel cells must be strapped and not flange mounted
9. Minimum 2 5lb fire extinguishers must be mounted within reach rescue personnel, and mounted in such a way as they are secure but easily accessed when needed.
10. Seats must be mounted securely to the cage or floorboards
11. All Wiring, brake lines, fuel lines and vent lines must be in good condition and secured as needed
12. Battery must be of a dry cell or gel cell construction and securely mounted with a cage, box, or over the top strap.
13. Rear facing amber light must be visible to rear approaching vehicles; light must be hard wired so it stays on with ignition switched on
14. Vehicles must be equipped with differential locking devices in both front and rear axles
15. It is highly recommended that vehicles be equipped with beadlock wheels
16. Vehicles must carry a small first aid kit
17. Driver and Co-pilot must wear helmets, helmets must be dot, SNELL or FIA approved. Helmets must be current in dating and in good condition.
18. High back seats or helmet pads must be used
19. Neck support devices are highly recommended
20. 1 piece fire suits and shoes are highly recommended
21. Window nets are highly recommended
22. Minimum 6000lb front mounted winch, winch must be operational
Here is a link to the rules directly from the WEROCK site:
http://www.werocklive.com/dirt-riot-trail-class/
http://www.glfwda.org/
SUPPORT THE SPORT!
--l ,[____],
l---L –0lllllll0-
()_) ()_)--o-)_) .......
NightKrawler is offline   Reply With Quote
Old May 12th, 2012, 10:40 PM   #75
NightKrawler
KOH Jackhammer
2 questions...
1st, they state a 2 hour race on their website for modified......is that about right?
2nd...rules state this...6. Solid roof required, magnetic metal of at least .040 or aluminum of 1/8” in thickness acceptable
is this a must?
This came from the Dirt Riot Great Lakes 1 section on their website:
Friday Afternoon/Evening
Driver Meet and Greet at in Town Location
Saturday
Events Typically start at 9am and run until 5pm
6 Classes of vehicles racing all day
Ultra4 Qualifying
Stock Trail / Modified Trail / UTV -1 Hour Race
Modified 4500 / Stock 4600 – 2 Hour Race
Ultra4 Cars – 3 Hour Race
Awards Ceremony
After Party
I would direct questions to Big Rich Klein bigrich@werocklive.com (530) 417-5333
SUPPORT THE SPORT!
--l ,[____],
l---L –0lllllll0-
Old May 12th, 2012, 10:41 PM   #76
Tab
Tab's Avatar
2 questions...
is this a must?
I'm sure it would be. Pretty standard nowadays to have roof protection.
Tab is online now   Reply With Quote
Old May 12th, 2012, 10:53 PM   #77
Bruster
Ron,
Originally Posted by bigbchevy View Post
this
x2
Old May 13th, 2012, 06:31 PM   #78
Freak
Wheelin the HD
Freak's Avatar
X3
Old May 13th, 2012, 08:36 PM   #79
NightKrawler
KOH Jackhammer
2 questions...
is this a must?
I got an answer from Rich. A roof of some sort is required. I asked if a factory hardtop would work and this was his answer:
"just needs something to stop rocks from coming into the top of the cage in a rollover" If you or anybody else has any questions they should call or email him.
Rich Klein
phone: (530) 417-5333
email: bigrich@werocklive.com
SUPPORT THE SPORT!
--l ,[____],
l---L –0lllllll0-
Old May 13th, 2012, 08:50 PM   #80
Shotgun
I only wheel with boats.
Shotgun's Avatar
:sadpanda: will be heading down to Ann Arbor on the 9th.
Page generated in 0.57092 seconds with 83 queries
