Comanche -Sold- - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 22nd, 2011, 07:59 AM   #1
MB_Custom
Retro-Modder
MB_Custom's Avatar
Thumbs up Comanche -Sold-
88 Jeep Comanche 4x4 Pioneer Long Bed White
4.0 HO (Head 7120)
Manual 5-Speed (Ba-10/5 in excellent working condition)
NP231 Transfer Case
D30 and D35 with 3.55s
30x9.5Ē tires with about 40% tread
Rear sliding window
Comes with
Full Cap (red)
Truck Tool Box
Front Brush Guard
Full size spare
4Ē lift*
This has been my daily driver for several years. It has been very reliable and has always brought me home. Iíve kept up with maintenance and repairs, but now it is time to part ways. The rocker panels have some serious rust going but the frame, and the bed are solid. If you donít care about looks or can fix the panels, itíll go through several more winters. When I bought it, it had a blown head gasket. I pulled the head and put a revalved HO 7120 head on it. I also replaced the clutch and throwout hydraulic bearing at that time. It has probably had 15k-20k miles on it since then. Runs good, but seems low on power for an HO (rings?). Drive train is good, but I stole the front drive shaft to put onto my new vehicle. Suspension had a spring over in the rear (so 4Ē ish) and custom springs (prev owner) up front. Front springs need to be replaced. I have replacement springs that come with the truck. Needs a new headlight switch or plug that goes in the switch. Just went out recently and donít have time to look into it (I wired the fog light switch to the headlights for now). The bracket for the rear bumper needs some angle iron or something. At some point it could use a new radiator. Otherwise, this has been an excellent vehicle. Itíd be perfect for plowing, hauling lumber, or just a winter driver.
I have pix. Will post soon. Till then, I posted with pix here:
http://annarbor.craigslist.org/cto/2779228302.html
Asking $600 or BEST OFFER or Trade / Barter
SOLD
MB_Custom is offline
Old December 26th, 2011, 02:49 PM   #2
rjh6355
rjh6355's Avatar
interested in selling or trading just the lift???
rjh6355 is offline
Old December 26th, 2011, 02:52 PM   #3
newdodge
jeep life
newdodge's Avatar
if you were closer i have cash in hand
newdodge is offline
Old December 26th, 2011, 10:10 PM   #4
MB_Custom
Retro-Modder
MB_Custom's Avatar
No time to part anything out. As for the 'lift', stock MJ Comanches are spring under, so it simply has new perches on the top of the axle making it spring over (like an XJ) and new shock mounts. The front springs on it need to be replaced and the coils that I am including with the vehicle are stock height (which is *higher* than what the front is sitting at now in those photos). I also have 3/4" polyurethane lift spacers that could go with this for the front. Otherwise, the Front Coils for an 83-97 Thunderbird with a V6 give a nice ride and a 3-4" lift. 1970something F150/Bronco springs give the same lift but are stiffer. Or there are polyurethane 'poorman' lifts as well that are dirt cheap.
Old December 26th, 2011, 10:13 PM   #5
ronprice
ronprice's Avatar
give it till late Jan /Feb . Tax time it will go quick
ronprice is offline
Old December 27th, 2011, 08:37 PM   #6
dfreeman616@gmail
dfreeman616@gmail's Avatar
Send a message via AIM to dfreeman616@gmail
as for bartering...i'm a licensed mechanic, get the parts and i'd be willing to trade some labor to set it up for you.
dfreeman616@gmail is offline
Old January 4th, 2012, 02:13 PM   #7
redram98
redram98's Avatar
drive past this truck everyday on the way into work. free bump
redram98 is offline
Tags
4x4, cherokee, comanche, jeep, truck
Page generated in 0.24254 seconds with 44 queries
