4418 PAC Racing / Motor City Machines 2012 KOH Thread - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 13th, 2012, 12:31 PM   #61
Originally Posted by Bones View Post
Thanks again to Motorcity Machines for helping me out last night. Time is tight for KOH prep but Mike still took 3 or 4 hours away from his build to make sure I was ready for KOH too.
I really appreciate it.
HUH? If I had known you were there I would have brought over your present.
Old January 13th, 2012, 12:34 PM   #62
Bones
Bones's Avatar
I didn't get there until 9pm, it was a late night.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 13th, 2012, 01:13 PM   #63
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Originally Posted by hosejockey4506 View Post
i was just so flustered after john wrecked the engine cover.
pfft
Old January 15th, 2012, 08:42 AM   #64
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Sitting on tires, everything moved a bit further along. Rebuilt 4L80E from Tranny Tom is hooked up to the Atlas 2.0 and installed in the rig. Trying to get as much done around the engine as we can.
Old January 15th, 2012, 09:12 AM   #65
bbaXJ
Yooper In Training
bbaXJ's Avatar
Looks awesome! Any concerns with the higher first gear of the 4L80E coupled with the higher low range of the Atlas not being low enough for crawling? Obviously it's light enough and powerful enough that it shouldn't be a huge issue, just wondered if it's a concern at all
Old January 18th, 2012, 03:17 PM   #66
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Hopefully not. In most of the races, the obstacles aren't the same as a competiton rock crawl where there's a lot more technical driving. Most of the obstacles require getting through an area quickly with less restrictions on the line you have to take, so it should not be an issue.
The hope is to be able to run all or portions of a race staying in low range to limit shifting in and out of gear. This is an especially good strategy at races like Rausch Creek where there aren't long high speed stretches, so he can run 4th gear in low range near red-line up near 70-90 mph, depending on how the new engine mods like hanging up there for short bursts.
Shifts into and out of low range can take 10-30 seconds depending on if the shifters bind up, so it can be quite an advantage to roll up to an obstacle, clear it, and get back up to race speeds. Sometimes making the pass going into an obstacle due to them not getting a clean shift could mean a big speed advantage.
As a comparison, Randy Slawson in his Bomber buggy tends to run most of KOH in low range, but runs 4.10 gears vs Mike's 5.40; so he has even worse crawl capabilities.
Our hope is to get some good prerunning in out at KOH so we can nail down the strategy. For RCQ we had marks dropped on the GPS that showed when to shift in and out so the co-driver could call it out, hopefully we have very few of those.
Old January 18th, 2012, 03:24 PM   #67
Bones
Bones's Avatar
...that is no joke... I don't think I'm going to bother shifting in the qualifier.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old January 18th, 2012, 03:30 PM   #68
kickstand
circling the drain
kickstand's Avatar
Looking good Mike, good luck out there.
Old January 23rd, 2012, 11:57 AM   #69
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
We got the engine back on Friday night after a couple of frustrating days at the dyno, and no run time. Mike had a new harness made that turned out 99% awesome, but was lacking one power wire that caused the dyno guys to not be able to tune the engine.
Within an hour of getting the engine and harness, Mike and I were able to track down the issue and patch in the missing wire. It should be good to run when we get to that point, but it looks like we'll tune the engine in on a local chasis dyno instead of the engine dyno.
We re-flipped the intake to fit in the chassis and tried to install the engine on Friday night. We figured out that pulling the crank pulley was gonna be the ticket, and called it a night.
After some sleep and with a smaller 3-jaw puller on hand, Mike and were able to drop the engine back in the chassis on our first shot. Two tabs were in the way, but no big issue.
WhiteRhino stopped by and he and I made up some new engine plates that raised the engine about 1" to allow a bit more uptravel. Meanwhile Craig (Vu14TJ) and Mike laid out the wiring harness and adding heat shield where needed.
ID:	88229   Click image for larger version
Old January 23rd, 2012, 12:01 PM   #70
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I guess I forgot about the new torque convertor. Before we married the engine and trans, we installed Mike's new TCS torque convertor. He ran last year with a stock 4L80E TC, but he wanted to take advantage of the cam and head upgrades so he stepped up. There's no lock-up and it's about 2800rpm stall.
He also picked up this trans cooler. With the radiator in back, we can fit it in the retrurn line from the radiator to engine to cool the trans. Come to find out, it's not much easier to package than a air cooler, but now that a spot has been found, it should be sweet.
ID:	88231   Click image for larger version
ID:	88232   Click image for larger version
Old January 23rd, 2012, 12:42 PM   #71
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
The radiator got to the shop on Saturday night and we got to work installing it. It's a BeCool 36x19 with two 16" SPAL fans. It should have no problems keeping the motor cool, as last year he ran a 26x19 with to two 11" SPAL fans.
PAC also made up some new posters. These turned out sweet.
On Sunday, Mike and Craig continued to knock out tons of stuff from the list. Engine should be ready to for first fire soon.
ID:	88234   Click image for larger version
Old January 23rd, 2012, 02:12 PM   #72
liv2mx
i like jungle gym's.
liv2mx's Avatar
when you guys leaving? looking good good luck this year..dont run over any winch lines this time...see you guys out there.
liv2mx is online now   Reply With Quote
Old January 23rd, 2012, 03:04 PM   #73
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Plan is to be on the road Friday, Feb 3. With good weather, we should be on the lakebed on Sunday morning.
Old January 23rd, 2012, 03:23 PM   #74
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
motor is most of the way plumbed and wired i spent a few hours out there last night with mike doing the little things on it.
Old January 23rd, 2012, 04:12 PM   #75
Yesterday we spent some time getting the remote oil cooler mounted with a new bracket. Also got the power steering cooler and oil surge tank mounted. Had to make new lines for the remote trans cooler.
I'm hoping to make the new switch panel labels tonight.
Old January 23rd, 2012, 06:39 PM   #76
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
on your kick ass router?
Old January 23rd, 2012, 06:48 PM   #77
4Bangler
Jackstand Wheeler
4Bangler's Avatar
Keep awn it guys, tick tock tick tock.
I'm rooting for you to have a trouble free fire-up and some quality tune time with hopefully a few hours of relaxation before race day.
Old January 23rd, 2012, 07:07 PM   #78
Yeah but not gonna happen. Been sick all day.
Old January 23rd, 2012, 07:10 PM   #79
Christmas Cookie
I can make you feel better...still want to buy the chipper/shredder? I dont want to take that thing apart to make the mini bike when I can just buy one already done
Old January 23rd, 2012, 07:43 PM   #80
chevotass
chevotass's Avatar
i swear mike cant function unless he has a deadline. he always finds a way to get it done as well. keep it up boys.
Page generated in 0.48280 seconds with 84 queries
