4418 PAC Racing / Motor City Machines 2012 KOH Thread - Page 10 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 29th, 2012, 07:10 PM   #181
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
Originally Posted by KILLER"B"468 View Post
tires are heavier, may slip on the rollers less than slicks or a smaller size tire. yes they do make a difference on the dyno. It may not be a lot but hell numbers is numbers right.
Horse power is horse power, tire size shouldn't matter spinning a calibrated drum. Dyno results are always corrected to sea level. To make a proper dyno run, specs need to be imputed into the dyno. They want to know tire size and gearing so that the dyno can compensate for each setup.
Changing gears will increase the amount of torque multiplication. Dyno results are base on torque then hp is calculated from the results. Putting in the lower gear then increasing the tire size will still give the same amount of torque but the mph should be higher because of the taller tire.
Not all dynos are the same. Getting a dyno run at one shop then getting another the next day at another dyno can give different results.
Old January 29th, 2012, 07:18 PM   #182
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
I agree but a taller heavier tire that can and may slip to being bigger and heavier will rob torque which is hp in the end. A smaller tire that hooks will hold the drum much better, that is what I was getting at. Giving a more accurate evaluation.
Old January 29th, 2012, 08:53 PM   #183
chevotass
chevotass's Avatar
enough dyno talk. is this thing jumping shit yet.
Old January 29th, 2012, 09:07 PM   #184
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
It was a good weekend at the shop. We are in good shape with the week coming up. There's a few things on the list, but anybody that's been around Mike before a race knows he will always find something to work on up until you shoot him or start the race.
When I left this evening, the stuff on the have to do list was front limit straps, engine/trans/t-case breathers, window nets, passenger seat belts, two panels were done but needed final fitting, install sway bar, winch ropes, tire hold-down, fiberglass/lexan skins, install skid, and I'm sure a few other items.
As for the dyno numbers -- who cares. Sure, it'd be nice if they were higher, but the important part is the tune chased out a few gremlins from last year and the engine should not hurt itself.
ID:	88530   Click image for larger version
Old January 29th, 2012, 10:07 PM   #185
Christmas Cookie
true...but his larger/heavier tires are offset by his gear ratio
Old January 29th, 2012, 10:38 PM   #186
Christmas Cookie
so I take it nobody won the hat huh?
Old January 30th, 2012, 01:48 AM   #187
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
oh really
Old January 30th, 2012, 05:28 AM   #188
Mr.Green
I can levitate!
Mr.Green's Avatar
Mr.Rong strikes again and again.
Old January 30th, 2012, 08:55 AM   #189
vu14tj
The car is looking good, wish I could've came up and helped. That is a long 8hrs of driving if I can't put in a whole weekend or at least a whole day. See you guys on the lake bed if I survive my trip from Vegas in an RV full of Aussie's!!!
vu14tj is offline   Reply With Quote
Old January 30th, 2012, 09:37 AM   #190
KILLER"B"468
Yankabilly
here is an example from when I ran mud bogs. 39.5" bogger/rim combo weighing in at 145 ea. thats 290 lbs of rotating mass, when I ran comp class I ran a 36" super scoop that had 3" scoops on them making them 39" and the rim/tire weighed in at 78 lbs ea. 156 lbs rotating mass thats 134 lbs lighter in the rear for rotational mass when running the lighter tires. It lit those tires quicker with no bottle than it did the heavier combo with the same gear ratio. Free horse power because of the less rotational mass.
I guess my humor above in the first post was taken wrong I am out trying to discuss this. I have made serious horse power for years and ran all different sizes of tires. Mike has a ripping machine period and I speak to take nothing away from that!
Old January 30th, 2012, 10:30 AM   #191
Christmas Cookie
Originally Posted by hosejockey4506 View Post
oh really
yes lawn cutter, care to prove me wrong
Old January 30th, 2012, 12:05 PM   #192
alumcj
alumcj's Avatar
So....that was a train wreck for a few pages while i was working on the car. All i know is pulling in 2nd gear spins a whole lot more crap than spinning in 3rd gear and that will change numbers...
233 HP (not corrected)
Lets call it 273HP (add 40 since it was a 2nd gear pull)....whos closest to 273? PM me your address or come by the shop for your shirt!
alumcj is offline   Reply With Quote
Old January 30th, 2012, 12:08 PM   #193
trailrail302
Im going FAST!!!
trailrail302's Avatar
BBAXJ said 276 thats pretty close not sure if anyone else was closer.
trailrail302 is offline   Reply With Quote
Old January 30th, 2012, 12:09 PM   #194
alumcj
alumcj's Avatar
yup...i think hes the weiner.
Old January 30th, 2012, 12:12 PM   #195
bigbchevy
missmrgreenagain
bigbchevy's Avatar
i will take his hat as trade for my fence that he ran his jeep in to
H.o.r.e
Old January 30th, 2012, 01:00 PM   #196
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
I think you should add 50, of course. Since I said 275/305 .
Good luck at the race!!
RIP FULLSIZE4LIFE
Old January 30th, 2012, 01:10 PM   #197
bbaXJ
Yooper In Training
bbaXJ's Avatar
I've been wanting to come and see the beast anyway....should I just stop by one evening? I imagine at this point you're out there anytime you're awake and not at work.
I didn't even do any damage!!!
....did I? The lawn on the other hand, I messed that all up pulling out the minivan
Even beyond the weight of the rotating parts, I've heard time and again that tread compound and air pressure can make big differences too. With sticky tires and relatively low pressures I'm sure the numbers were lower because of that too. Basically everything that makes Mike's buggy awesome offroad makes it terrible for making impressive numbers on the dyno, no matter how fast or powerful it really is.
bbaXJ is online now   Reply With Quote
Old January 30th, 2012, 01:24 PM   #198
alumcj
alumcj's Avatar
any night after 8pm except tonight. I have a night off!!!!
Old January 30th, 2012, 01:25 PM   #199
I believe a wider tire will also add more rolling resistance. Hence why a bicycle rider uses skinny tires on road bikes. Pretty scientific eh?
Old January 30th, 2012, 01:35 PM   #200
bbaXJ
Yooper In Training
bbaXJ's Avatar
Good for you!! (and probably your wife and kids)
I'll probably come by either tomorrow or Thursday....not just for free shit, I haven't seen the rig or most of you guys in quite a while
Page generated in 0.54317 seconds with 84 queries
