FJ40 getting some much needed up-grades! - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 13th, 2012, 12:32 AM   #61
mybluetoy
4-wheel 4-life
mybluetoy's Avatar
Here are some pics, front hoops were made along with front drive shaft, ride height is about 2" lower than where it sits, rear pinion flange for 14 bolt was made, radiator was moved forward a few inches, and electric fan was installed. Still have steering, brake lines, shocks, rear drive shaft, and some touch ups, oh and exhaust. Getting closer but so is October.
ID:	95468   Click image for larger version
ID:	95469   Click image for larger version
ID:	95470   Click image for larger version
mybluetoy is offline   Reply With Quote
Old August 15th, 2012, 06:46 AM   #62
mybluetoy
4-wheel 4-life
mybluetoy's Avatar
Built the rear drive shaft. It happens to be a 1/4" shorter than the front so I decided to make a spare. Felt great knowing that the front and rear are interchangable. Starting the full hydraulic steering next.
Old August 16th, 2012, 03:29 PM   #63
crosseyed cat
safety cone killer !!!
crosseyed cat's Avatar
I was told school is out !!! burn some wire on this b!!ch and lets roll
crosseyed cat is offline   Reply With Quote
Old August 16th, 2012, 08:19 PM   #64
mybluetoy
4-wheel 4-life
mybluetoy's Avatar
Been out of school for two weeks. The wick is lit at both ends. Been working out there every night. Steering, brake lines, shocks, exhaust, traction bar, and fill with fluids. Those are the major things left. a bunch of little things to do too, but she'll be at Loonie.
Old August 17th, 2012, 08:04 AM   #65
liv2mx
i like jungle gym's.
liv2mx's Avatar
looks good john. too bad it was not done for this weekend.
Old August 17th, 2012, 09:39 PM   #66
mybluetoy
4-wheel 4-life
mybluetoy's Avatar
Thanks, yeah I wish it was done for this weekend too, have fun, I had so much fun last year, I'll be there next year! See you in a few weeks.
Old August 21st, 2012, 08:39 AM   #67
mybluetoy
4-wheel 4-life
mybluetoy's Avatar
Hard doors, hard top, windshield are off and moved into storage. Brake lines, master brake cylinder, some fluids, traction bar, start steering, and the little things are started and moving along. Might have it done early next month, might?
Old September 6th, 2012, 04:52 PM   #68
mybluetoy
4-wheel 4-life
mybluetoy's Avatar
Working on the steering, and then bringing it to G&M to do the exhaust and check the brakes. Shocks should be in tomorrow or Monday. Should be ready to go wheeling soon!
Old September 6th, 2012, 08:24 PM   #69
liv2mx
liv2mx's Avatar
better get a shakedown run in before we go to canada...
Old September 6th, 2012, 09:58 PM   #70
mybluetoy
4-wheel 4-life
mybluetoy's Avatar
That would be nice, but it might be Canada?
Old September 15th, 2012, 11:40 PM   #71
mybluetoy
4-wheel 4-life
mybluetoy's Avatar
Update - Shocks have been mounted, Full Hydraulic steering is done, started up the old SBC and it awoke on the first try, A bunch of little things to do and two big items yet, brakes and steering, getting those taken care of next week. After all the little stuff and the two big items are finished, then it is time for the I WANT LIST, too much to list but will post when I get there.
Old September 16th, 2012, 12:43 AM   #72
two_much_talk
sit down shut up and ...
two_much_talk's Avatar
Old September 16th, 2012, 08:14 AM   #73
mybluetoy
4-wheel 4-life
mybluetoy's Avatar
Here are some pics:
ID:	96666   Click image for larger version
ID:	96667   Click image for larger version
Old September 24th, 2012, 10:43 PM   #74
mybluetoy
4-wheel 4-life
mybluetoy's Avatar
So the brakes, steering, and exhaust are done, I think. Thought I had the steering done before, it was tough to steer so I replaced it with a new pump. Drilled the high pressure fitting out an 1/8" more, added a inline cooler. The difference is like night and day. Need to test the brakes now, add lights, and tunes. I'm now starting to gather up extra parts, just in case.
Old September 27th, 2012, 08:08 AM   #75
mybluetoy
4-wheel 4-life
mybluetoy's Avatar
Picked up my chromoly 4340 Yukon inner and out 35 spline from Rock Solid Performance out of Cedar Springs Michigan. They have a sweet shop, first time I've been there. Many projects, and some cool after market parts. The shafts will help me keep it wheeling. I think now my weak spot is the transmission or T-case. Those are the original 72 Toyota FJ40 transmission and T-case. Although the drive shafts could be it too?
Old September 29th, 2012, 06:26 AM   #76
mybluetoy
4-wheel 4-life
mybluetoy's Avatar
to much talk stopped by with his charging system. It looks so much better, thanks Ben! Drove it around, flexed it out. Before I took it for a spin we had a small electrical fire under the dash I need to gut the electrical system and run a simple harness, maybe do that tomorrow?
Old September 29th, 2012, 07:28 PM   #77
two_much_talk
done yet ?
Old September 30th, 2012, 10:51 AM   #78
mybluetoy
4-wheel 4-life
mybluetoy's Avatar
Not sure it'll ever be done, but it is close to being ready
Old September 30th, 2012, 08:54 PM   #79
mybluetoy
4-wheel 4-life
mybluetoy's Avatar
It's ready, not sure how long it'll last shakedown run in Canada on Wednesday night/Thursday morning at Curly's place. Figure that's the best place for the shakedown. I'll have to redo the harness, we have all different color wires running in every direction I'll redo it after the trip. Next is to add a rear 4-link. The front was educational to say the least. Driving it around it feels stable, played on a dirt hill, I need lower gears, 4:10s are to fast. Lots to change but first time to play!
Old March 11th, 2013, 09:03 PM   #80
mybluetoy
4-wheel 4-life
mybluetoy's Avatar
After Canada and two tie bars that broke, I got the other high steer arm, which still needs to be put on. I also smashed in both differential covers, bought some HD ones and just installed them last week after our trip to Super Off Road Park in Hot Springs, Arkansas. While we were in AR I broke the transfer case front cone housing, was going to put in a whole different trans and case but we have this Extreme Truck Challenge coming up and really want to play with the Extreme guys, So I just replaced the transfer case. Need to do high steer and add another battery for the winch in case I need it, to help some of the buggies roll back over Plenty of time, I think to do it all.
ID:	103023   Click image for larger version
Page generated in 0.43214 seconds with 84 queries
