Are the motor mouns the same? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 20th, 2011, 07:42 PM   #1
rehab532
rehab532's Avatar
Default Are the motor mouns the same?
swapping out a 351m and putting in a 460. are the motor mounts the same or will i have to pick up a set??? swapping in a 79 f 150 4x4
rehab532 is offline   Reply With Quote
Old December 20th, 2011, 08:04 PM   #2
lilbigfoot93
cant cash my checks
lilbigfoot93's Avatar
call jeffs bronco graveyard they are diff. and will need changing but it is not big deal he will have all of the info if not call l&l they have the parts also
lilbigfoot93 is offline   Reply With Quote
Old December 20th, 2011, 08:05 PM   #3
rehab532
rehab532's Avatar
thanx. plan on doing the swap in a few weeks so wanted to make sure i have all the right stuff
Old December 21st, 2011, 10:42 PM   #4
pkupman82
Yes the mounts are different, you can buy the conversion mounts that will bolt right in with no mods. I bought mine from Jeff's Bronco Graveyard for the 460 in my 79 Bronco. They're also available from L&L products.
pkupman82 is offline   Reply With Quote
Old January 3rd, 2012, 12:06 PM   #5
TurdBronco
good info
http://www.projectbronco.com/Technic...alling_460.htm
Page generated in 0.16935 seconds with 38 queries
