1992 f150 idel problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 13th, 2005, 11:29 PM   #1
GarDavidson
GarDavidson's Avatar
Default 1992 f150 idel problem
I have a 1992 f150 5.0 auto trans. It never seems to go out of high idel any suggestions. A freind said it maybe the cooling sencer?
GarDavidson is offline   Reply With Quote
Old December 14th, 2005, 08:21 AM   #2
Bones
Bones's Avatar
how high is high? Do you have a tach? Generally the high idle right at start-up is calibrated for the cats to warm up (it is a predetermined amount of time), not the coolant sensor.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old December 15th, 2005, 12:47 AM   #3
GarDavidson
it is fuel injected the high idel is fine it is the lengh of time it is on it never goes off. it will be up to temp and still runs high no i do not have a tach. I can't find any thing in the book on the idel. is there a sencer that controls the idel or is there a adjustment to slow it down.
Old December 16th, 2005, 02:06 PM   #4
offroad86b2
offroad86b2's Avatar
Send a message via AIM to offroad86b2
you should have a idel adjustment on the throttlebody
offroad86b2 is offline   Reply With Quote
Old December 17th, 2005, 04:33 AM   #5
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
sounds like a vacuum leak, check the hoses at the back of the engine to see they are in tact. bad coolant sensors cause things like too much fuel when warm and rotten egg smell out the back. I have to believe its a leak.
Yetti
Old December 17th, 2005, 05:09 PM   #6
GarDavidson
i'll check for leaks thanks. if there is no leaks i try to adjust.
Old February 15th, 2006, 10:02 PM   #7
TurdBronco
spray around with carb cleaner and the idle should change. between upper and lower intakes can leak also.
you cant adjust the idle at the throttle body, its computer controlled.
Page generated in 0.28162 seconds with 44 queries
