Project Jimmycon (full width tons jk) REAL Cost!! - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 16th, 2012, 01:20 PM   #61
SweetLeah
<3's Ridin' Dirty
SweetLeah's Avatar
Originally Posted by indy View Post
It rides great on the trailer, unless your refering to pushing it out of the garage! Leahs right it was a rocket with two hillbillys riding it down the driveway!!
Other than that, the brakes are done, steering done, switched to a Rock solid front track bar with sector brace. It hits my hi steer arms at full lock so I'm just going to put some stops in. Its getting a cutting brake anyway so hopefully I won't miss a little turning radius. Switched to a Synergy rear trackbar.
The down side, I bought JE REEL drive shafts, and they aren't shipping out untill Monday! The up side. .120 wall shafts instead of .083
For this weekend I guess I'll rework my Shrock works rockers so they work with the long arm, I wasn't going to because of the whole cutting up perfectly good parts thing, but then I rememberd that I just cut a ton of stuff off a fairly new jeep!
You've never seemed to have problems cutting anything up. Like when you used a hole saw to cut open my XJ hatch.
When Ryan said you weren't going to use the sliders because they weren't going to work....my response was, "Why doesn't he just MAKE them work?"
SweetLeah is offline   Reply With Quote
Old January 17th, 2012, 08:32 AM   #62
indy
indy's Avatar
Its done, Cut up perfectly good rockers to fit my needs!
indy is offline   Reply With Quote
Old January 17th, 2012, 09:01 PM   #63
knixon804
THE GENERAL
knixon804's Avatar
thats a sweet build. any updated pics?
2011 F-350, DELETED, INDUSTRIAL INJECTION SINGLE TURBO.... TOW PIG
UNDER CONSTRUCTION: LJ, STROKED LS, ONE TONS, 42" MTRS
JK 3" BDS LIFT, 33" DURATRACS, STEELIES, WARN
OFF ROAD ANONYMOUS- PROUD TO HAVE A PROBLEM (231) 383-5664
knixon804 is offline   Reply With Quote
Old January 18th, 2012, 09:44 AM   #64
indy
indy's Avatar
Thanks, No pics yet, the avatar pic is the newest. I didn't realize that I was going to hit the KOH crowd when I orderd my driveshafts so I'm in a holding pattern.
Old January 21st, 2012, 08:43 PM   #65
indy
indy's Avatar
Drove it today about 100 miles!! It could use a steering stabilizer thats about it. I do have the ABS light on and the BAS lights, I need to do some fine tuning of the sensors and set the steering wheel to zero.
The speedo is working and about 9-10 mph off. The ride quality is better than stock, Well better than the 3.5" standard rubicon lift anyway. I may consider putting the stock springs back in. The 38s look like bike tires!
Old January 24th, 2012, 11:27 PM   #66
indy
indy's Avatar
DONE, Axles check! Long arm check! Schrock works rockers, reworked check! Custom rear swing out tire carrier check!
Old January 24th, 2012, 11:33 PM   #67
kb8ymf
Not as old as Whiterhino
kb8ymf's Avatar
Surprised you need a steering stabilizer. Whats your toe? I'd put hyd assist on instead to help move those 42's
j-kb8ymf
kb8ymf is offline   Reply With Quote
Old January 24th, 2012, 11:35 PM   #68
kixx007
Certified Ypsilantian
kixx007's Avatar
Junk.
kixx007 is offline   Reply With Quote
Old January 25th, 2012, 08:58 AM   #69
SweetLeah
<3's Ridin' Dirty
SweetLeah's Avatar
Spinnerz
Old January 25th, 2012, 10:00 AM   #70
indy
indy's Avatar
j-kb8ymf
Toe is set at 1/8" in, These tires are 14.50 wide so its not an issue all of the time only at slower speed.
Project manager (wife) put a halt on the budget so no ram assist YET, there not 42s. Instead of doing a build with small axles and big tires, I did a build using big axles and streetable tires!
Old January 25th, 2012, 10:11 AM   #71
SweetLeah
<3's Ridin' Dirty
SweetLeah's Avatar
I think Jim M. knows your CURRENT tire size. AND knows you well enough to know that this tire size is ONLY current. Your reputation precedes you!
Old January 25th, 2012, 12:25 PM   #72
indy
indy's Avatar
When I was at the tire place getting them balanced yesterday which was a wreck, I decided that 26s on some 31. 10.50s are my new deal! Oh but wait I had to put spacers on the rear so they won't sell them to me
Old January 25th, 2012, 01:38 PM   #73
SweetLeah
<3's Ridin' Dirty
SweetLeah's Avatar
You Haez Spazerz? Oh Dangers!
Old February 24th, 2012, 07:25 AM   #74
indy
indy's Avatar
This build is done for now, I have put about 75 trail miles on it and my wife hass put about 1000 road miles on it. I thought I would put down the real cost of what a person could build there own 1 ton jk for. I've seen alot of debate so here it is.
Cost of Jk= your choice
cost of 1979 Dana 60s (4500) in my case a person could get out way cheaper!
Cost of Currie rock jock brackets (most of them worked) 750
Cost of JE REEL drive shafts 1300. I added the Canyon Crawler upgrade for an extra 100 on the rear.
Cost of Teraflex Master cylinder 195 (without it the pedal is mush)
Cost of wheels (Cuz your gonna have 8 lugs not 5 now) 400
Steering 120 (3) 7/8x 14 fk rod ends 120
Tone Rings for ABS 280
Total cost $7545.00
I did not include the cost of Stauns tires or my lift because those were my choice.
I think atleast a budget boost is needed.
In my opinion if you already had a set of Ford 60s this could be way cheaper!
I set out to build something way stronger than a Rubi and be close to the original cost and have it still be my wifes DD (tested to 75mph). All ABS works as well as traction control! The air pressure light is on due to Stauns I can't use the pressure valve stems.
I would do this again in a heartbeat, My only regret is not buying 40" tires! With 3.5" of lift there is plenty of room for them! In time!
Happy Building!!
Old February 24th, 2012, 07:40 AM   #75
mschaffer66
mschaffer66's Avatar
Did you end up just putting all 4 sensors on the rear axle then? or did you get the tone rings on the front as well?
Old February 24th, 2012, 08:07 AM   #76
kixx007
kixx007's Avatar
Tone rings on the front. Jim doesn't half ass anything. He does it right.
Old February 24th, 2012, 08:12 AM   #77
indy
indy's Avatar
All the way around! In fact in this crazy snow storm today (riiiiigghht) I just took my wife to work in the jk and the traction control stuff worked really well!
The speedo is about 10 MPH off. I haven't corrected that yet either, however the shift points are dead on so why bother!
Old February 24th, 2012, 02:18 PM   #78
buildingup
Pictures?
buildingup is offline   Reply With Quote
Old February 27th, 2012, 08:49 PM   #79
indy
indy's Avatar
Rear bumper pics, Spindles are both lockout hubs one from my 67 cj5
ID:	89669   Click image for larger version
Old February 28th, 2012, 09:37 AM   #80
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Very nice rig.
RIP FULLSIZE4LIFE
Page generated in 0.55508 seconds with 84 queries
