Project Jimmycon (full width tons jk) REAL Cost!! - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 27th, 2011, 08:43 AM   #21
indy
indy's Avatar
Parts ordering day! Debating full double ended hydro setup, or ram assist. In the past I have made my own double ended ram setups. I'm thinking if I buy a PSC kit, but run it through my stock steering pump this would make it slow enough for a daily driver!? My past buggy I had zero issues with road driving? COMMENTS??
indy is offline   Reply With Quote
Old December 27th, 2011, 08:51 AM   #22
mschaffer66
mschaffer66's Avatar
I think if/when I do this I would do a setup like Rocksolid did with the double ender(lol) being used as assist.
Old December 27th, 2011, 09:43 AM   #23
indy
indy's Avatar
I haven't seen this, maybe I should check it out! It was just pointed out to me that if a desert race truck can fly at 120mph straight than I should be able to do 55 mph on the street! My old rig I had at 75 mph a couple times with full hydro.
Old December 27th, 2011, 09:59 AM   #24
RockSolid Perf.
RockSolid Performance
RockSolid Perf.'s Avatar
http://www.rocksolidperformance.com/..._signature.gif
www.RockSolidPerformance.com. We are dealers for AEV, Metalcloak, Motor State, Poly Performance, PSC, Yukon Gear. Like Us on Facebook.
RockSolid Perf. is offline   Reply With Quote
Old December 27th, 2011, 10:00 AM   #25
RockSolid Perf.
We used a double ended ram as the Drag link and hydro assist.
Old December 27th, 2011, 10:13 AM   #26
indy
indy's Avatar
Thats pretty trick! So then does that use the PSC kit fot the steering box or did you do the machine work yourself? That looks like a Rock Jock axle. If anything I may be able to keep the ram higher since I'm using a kingpin axle with highsteer.
Old December 27th, 2011, 10:17 AM   #27
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Very nice!!
RIP FULLSIZE4LIFE
Old December 27th, 2011, 11:26 AM   #28
RockSolid Perf.
We used PSC pieces, its not a kit. In fact they told us it would not work. its is a PSC pump,PSC Box and ram. we couldnt run High steer on both sides due to clearance issues with the frame. The new owner wanted it low with 42" tires
Old December 27th, 2011, 11:43 AM   #29
indy
indy's Avatar
I love it when they say it will never work! I've gotten that twice with this project already! I just kinda figured I would bump stop the drivers side a bit taller if I used the high steer.
Old December 28th, 2011, 09:48 PM   #30
indy
indy's Avatar
Second set of tone rings came today. I pushed them on by hand, they are square and tight, however I plan to tack weld them to be sure!
Heading to St. Helen this weekend to install the long arm and test fit the axles.
Old December 28th, 2011, 10:03 PM   #31
kixx007
Certified Ypsilantian
kixx007's Avatar
Tone ring on the rear hub!
kixx007 is offline   Reply With Quote
Old January 2nd, 2012, 09:14 PM   #32
kixx007
kixx007's Avatar
Went up and helped Indy check axle fitment over the weekend. We also had a chance to install a Rubicon Express long arm upgrade kit.
Front axle all tacked up and sitting in there...
http://www.flickr.com/photos/73378327@N05/6624672177/
The rear axle was mocked up on the bench, taking measurements from a stock JK D44, that was not in a vehicle. Worked out pretty good.
http://www.flickr.com/photos/73378327@N05/6624668161/
And then we decided to do the long arm kit... Which commenced with Jim getting the plasma cutter out and whacking brackets off. It's not often I see someone hack up their Jeep that's hardly a year old... Does this void the warranty?
http://www.flickr.com/photos/73378327@N05/6624664395/
Old January 2nd, 2012, 10:05 PM   #33
indy
indy's Avatar
I'll keep cutting off the bad parts if you keep taking the pics!
Old January 3rd, 2012, 05:33 AM   #34
4Bangler
Jackstand Wheeler
4Bangler's Avatar
Make him take the red "X" off the camera lens next time...
Old January 3rd, 2012, 09:33 AM   #35
kixx007
kixx007's Avatar
I took the image tags off so it's just the links now. Clearly I can't post pictures.
Old January 3rd, 2012, 10:30 AM   #36
Bustabizz
Looks good man!
Bustabizz is offline   Reply With Quote
Old January 4th, 2012, 01:53 PM   #37
indy
indy's Avatar
I just finished the front ABS brackets, I ended up using Dynatrac supplied brackets which I used my backyard Bridgeport (Metabo) to modify as needed.
Later tonight I will be finish welding the front axle and messing around mounting the Stauns and tires to the wheels.
All is looking good for final install this weekend!!
Old January 4th, 2012, 03:01 PM   #38
mschaffer66
That's awesome looking :)
Old January 4th, 2012, 03:57 PM   #39
All5ofus
All5ofus's Avatar
Can't wait to see it in action at SnoFari in a few weeks. Looking good.
All5ofus is offline   Reply With Quote
Old January 6th, 2012, 09:02 AM   #40
indy
indy's Avatar
Thanks looks like I'll have it on rubber by Saturday night. Probably will make my own driveshaft to test drive it!
Page generated in 0.45119 seconds with 84 queries
