anyone good with triton motors? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 19th, 2011, 08:39 PM   #1
masterbeatty
masterbeatty's Avatar
Default anyone good with triton motors?
looking to pull my motor and set it in another truck. while it is out i have a set of cams for it, so i figured cams, chains, oil pump bearings, gaskets. well i dont know how to time them. i tried before but it was a mess. anyone good with them that can offer advice?
Old December 19th, 2011, 08:47 PM   #2
xj97sport
atv rider
xj97sport's Avatar
I got alldata if that helps.
Old December 19th, 2011, 10:30 PM   #3
masterbeatty
i have mitchel at work. i have print out upon print out. i have the book. im sure i could do it but last time i was sure and i sent a valve into a piston. that made for me to be very unhappy. id like to find someone who has done this before that could offer up help or at least tips. but i do appriceate the offer.
Old December 21st, 2011, 09:46 PM   #4
masterbeatty
noone?
Old December 21st, 2011, 09:57 PM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
i just looked at the procedure on chilton, and it looks simple enough to me. align the copper links with the dots on the crank and cam, make sure the guides are in properly and the chain is tightened by the tensioners.
Old December 21st, 2011, 10:26 PM   #6
Goped_Rdr
8 Lug Thug
Goped_Rdr's Avatar
Send a message via AIM to Goped_Rdr
What year and is it a 4.6/5.4 2 or 3 valve? Id get tensioners too, check cam bearings/caps, while your at it do exhaust manifolds and gaskets because eventually they will leak and its hard in truck. Its pretty straight forward, roll motor over to line up dots, make sure it doesnt turn over when chains are off, (even take a pic if your not sure) and set everything back on the way it was. I like to outline a few of the gasket areas with silicone so they dont leak and make sure you torque everything to spec.
Goped_Rdr is offline   Reply With Quote
Old December 21st, 2011, 10:38 PM   #7
masterbeatty
98 5.4 2v im purdy fimilr with the triton motors as a whole ive had a few of them, i have headers to go on. i think my problem before was i spun it while the chains were off. have you done this without the tools? i dont have them to hold the crank.
Old December 21st, 2011, 11:09 PM   #8
Yota Bill
I have the complete Ford master timing tool set from Mac, that I'd actually like to sell. Most of the tools in the set have never been used. Its alot more tools then you need for this one job since it covered all Fords, but it has the tools you do need. It cost over $400, and I'm looking for $285
Page generated in 0.18429 seconds with 47 queries
