Stacking trailers - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 19th, 2011, 12:08 PM   #1
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Default Stacking trailers
I have two 18' car haulers now.
I'd like to stack them somehow so I have more room to put snow.
Anyone else do this? I don't have a forklift, one trailer has removable fenders.
Any ideas?
Old December 19th, 2011, 12:23 PM   #2
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Block the bottom trailer tires, hook up to the 2nd trailer with your truck/what ever you move the trailer with, and back the 2nd trailer onto the 1st. So pretty much your trailers are 69'ing.
Old December 19th, 2011, 12:24 PM   #3
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
Bring them down to me and I will stack them with the crane.
Old December 19th, 2011, 12:46 PM   #4
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Backing it on should work well didn't think of that I'll have to get some good 2x10's tho to support the top trailer the axles are wider than the decks.
Old December 19th, 2011, 12:49 PM   #5
Trailers aren't too heavy, so I'd just get a couple pieces of steel beam or tube, and a bunch of cinder blocks, and treat it like lifting a body off a lifted truck.
Lift one end with a jack or cherry picker, stack blocks and place beam across it to support that end fo the trailer, now go do the other side as high as you can. Then go back, jack it up, lift it up, add one more block, etc. Just make sure your beams are wide enough so that once its lifted up about 4 feet, you can back your second trailer underneath it.
If you are comfortable with it, you can just leave it on the tubes/beams all winter. Otherwise, put some blocks on the lower trailer that will support the upper trailer, and slowly lower and remove blocks.
Not super fast, but easy, and you only need blocks of some sort, and a couple 10ft pieces of tube or even some 4x6s (or even a couple 2x6s nailed together to make a few beams). So pretty cheap to do.
Advantage of this way, is that you can have both tongues stacked on top of each other. Less space taken up.
Old December 19th, 2011, 01:51 PM   #6
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I thought this was going to be a redneck version of some home improvement / makeover show.
@clarkstoncracker
Old December 19th, 2011, 02:22 PM   #7
First time I read it, I thought he was trying to stack them to load snowmobiles two high.. lol...
Old December 19th, 2011, 02:26 PM   #8
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Wow I'm retarded.. I have a friend with a John Deer tractor... Case solved
Page generated in 0.24091 seconds with 47 queries
