Wont shift out of 4LO - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 19th, 2011, 09:35 AM   #1
Timmy
Timmy's Avatar
Default Wont shift out of 4LO
I have a 05 GMC 2500HD.
When I shift the truck into 4LO it will not want to shift back into 2WD. I was finally able to get it to shift back after 20 min of playing with the push button switch and shifting it through the gears. I just replaced the accuator on the front axle. This still doesn not fix the problem. Some people have said it could be the push button switch. Any ideas?
Timmy is offline   Reply With Quote
Old December 19th, 2011, 12:02 PM   #2
in2deep
Hole tester
the mode motor on the t case
Old December 19th, 2011, 12:09 PM   #3
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
Sounds like Encoder motor on it's way out.
Old December 19th, 2011, 01:08 PM   #4
Tom
Because racecar
Tom's Avatar
^^^^^^ This ^^^^^^^
Old December 19th, 2011, 07:53 PM   #5
frdboy
frdboy's Avatar
X4.. Encoder motor maybe.
You do know it has to be in N, foot on the brake, not moving before it will try and shift out of low right??
Old December 19th, 2011, 08:10 PM   #6
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
It's probably just the sensor in the encoder motor. Mine went out and I had similar issues. It's like $108 for the part and you have to pull the encoder motor but a new motor is like $600 or something stupid high.
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old December 20th, 2011, 07:07 AM   #7
Timmy
Timmy's Avatar
Originally Posted by frdboy View Post
x4.. Encoder motor maybe.
You do know it has to be in n, foot on the brake, not moving before it will try and shift out of low right??
yes!
Page generated in 0.24316 seconds with 44 queries
