Proper Tire rotation? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 18th, 2011, 02:31 PM   #1
Gunsworth
Gunsworth's Avatar
Default Proper Tire rotation?
I was always told to rotate front to opposite side rear and visa versa. Just got my tires rotated at discount tire and noticed they just went front to back same side. I called them about it and they said it doeasnt matter with radials? i feel like the tires rotational direction should be changed with a rotation, am I wrong?
I still need to go back anyways, the tire they plugged is still leaking
Old December 18th, 2011, 02:41 PM   #2
14muddn
If the vehicle has a matching spare I like rotating all five moving in a constant clockwise or counterclockwise direction. That way when you need the spare you know the lugs are not frozen on, it has proper pressure, and you save a little life on all of the tires. If the tires are directional you don't have much of a choice besides front to back.
Old December 18th, 2011, 02:42 PM   #3
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Yes, tire rotation goes DF to PR, PF to DR, and both rears to same side front. Seems that tire places think since they're professional they know "everything"...had tire factory in Mt p tell me that retread tires are illegal in michigan
Old December 18th, 2011, 03:03 PM   #4
Pushbar79
It does not matter as long as they get turned
Pushbar79 is offline   Reply With Quote
Old December 18th, 2011, 04:26 PM   #5
1TFROT
1TFROT's Avatar
what they are suppose to do is fronts straight back and the rears cross as they go forward.
how do I know, I'm a manager for Discount Tire in Ill and that's how we are trained. it's not the only way, but the way we are trained so we are consistent every time. if they are directional, then it's just front to back, same sides
1TFROT is offline   Reply With Quote
Old December 18th, 2011, 04:33 PM   #6
shawn
Resident HVAC/R Jambi
shawn's Avatar
x2
Rears straight to the front, fronts cross to the back.
Old December 19th, 2011, 09:09 AM   #7
turnofftheradio
this is interesting to me. I was trained to rotate side to side, but over the last 10 years or so I keep hearing that swapping rotational direction can cause belts to shift. I have not changed rotational direction myself in over 5 years on any car I have owned, just front to back to avoid the shifted belt scenario. I have shifted belts on tires, but never since I quit crossing rotation, could just be luck... anyone able to bust this myth?
turnofftheradio is offline   Reply With Quote
Old December 19th, 2011, 09:34 AM   #8
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
The pattern doesn't really matter unless there is something specific about the tires (directional etc.) as long as the same pattern is always followed.
Unless you're on an oval running NASCAR laps all day, there usually isn't much of a need to cross the tires.
I've always done LF to LR and RF to RR.
Old December 19th, 2011, 09:47 AM   #9
JeepInABox
In too deep
JeepInABox's Avatar
back to front, front crossed to rear,
gives the tire some time to adjust to direction and less driveability issues.
JeepInABox is online now   Reply With Quote
Old December 19th, 2011, 12:52 PM   #10
Gunsworth
Gunsworth's Avatar
alright, guess i wont worry, I just know the fronts were put straight back (one front tire was recently replaced so I know it was sent straight back, not sure if fronts were crossed or whatever)
this is on my chevy 2500hd, so I cant complain, I hate taking off those wheels, (including the stupid plastic center cap retainers) basically taking 16 bolts off each wheel sucks.
Old December 19th, 2011, 01:02 PM   #11
michigan maniac
michigan maniac's Avatar
My shop rotates front to back, back to front with no cross, unless there is an issue with the tire pulling then we will cross rotate, its all a preference on the shop, we do free rotations every 6000 miles if you bought the tires from us,
Old December 19th, 2011, 01:05 PM   #12
Elvis13
If you keep swapping straight back and straight forward you are not accounting for one side wearing uneven. By crossing it will allow all 4 tires to reach all 4 locations in 4 rotations.
Old December 19th, 2011, 01:11 PM   #13
michigan maniac
How will one side wear uneven? No matter where the tire is placed on the vehicle it will always have the inside edge be the inside edge, unless its a duely rear end or you break the tire down and flip it over on the rim
Old December 19th, 2011, 01:38 PM   #14
GreaseMonkey
Pew pew!
There aren't many vehicles that have enough negative camber for this to be an issue. If one side is wearing uneven, it means you need an alignment.
Old December 19th, 2011, 02:30 PM   #15
That being said, there's a lot of cars out there that do need an alignment, and people aren't aware.
I still see a lot of tires that have their tread blocks worn more on the leading edge and less on the trailing edge. Swapping side to side helps this.
Other small factors that don't make much difference, but 50,000 miles can show up
Typical car is also heavier on the drivers side due to single occupant often.
Cars don't always see the same amounts of left and right turns.
Drive wheels don't wear tires evenly. Right rear on a pickup for example.
So, generally accepted for radials is whats already been listed: move the rear forward, fronts to opposite rear. Most new car owners manuals show this pattern.
myself, I can't remember the last time I rotated tires. Maybe 15 years ago. But, it was also 15 years ago since I kept a car long enough that I had to replace a worn set of tires. lol.
Old December 19th, 2011, 06:05 PM   #16
littletrucker
I'd hit that
littletrucker's Avatar
This...
If you dont rotate your tires side to side then you will never get them wearing in the other direction, but if you dont know or dont care what makes tire noise then it doesnt really matter..
BUT there is a direction that your tires will roll the quietest in especially after they have gotten that "choppy" wear to them (directional tires you really cant do anything with)
Feeling a tire will give you the best idea of how they should be rotated, not every car wears tires the same, rears straight forward, x pattern. We do what ever feels the best.
(if you feel the leading edge of a tread block and it is higher than the trailing edge of the last tread block the tire will be noisy rotating in that direction. if you just go straight back or forward it'll never get better only worse)
ON a side note I wouldn't suggest plugging a tire.. repairing with an inside patch or inside plug/patch is 1000x better
Old December 19th, 2011, 08:05 PM   #17
michigan maniac
Thumbs up
Originally Posted by littletrucker View Post
This...
Very well said !!
Old December 20th, 2011, 06:37 AM   #18
GreaseMonkey
Pew pew!
I guess on the vehicles I've owned I always rotated tires often enough where uneven wear was never an issue.
Old December 20th, 2011, 08:52 PM   #19
Gunsworth
Gunsworth's Avatar
I get the free rotations and usually do it around every oil change :) Might just go little early this time and request they cross them.
This post was more out of curiosity of what the standard is than anything else.
Page generated in 0.39626 seconds with 80 queries
