XJ: Steering wandering & "notchy" - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 18th, 2011, 01:01 PM   #1
jcd302
Grace &/or Derek's Dad
jcd302's Avatar
Default Steering wandering & "notchy"
Everything is tight, except the steering box has a little play in it.
jcd302 is offline   Reply With Quote
Old December 21st, 2011, 10:00 PM   #2
littletrucker
I'd hit that
littletrucker's Avatar
bent steering stabilizer, bad ball joints?
Old December 21st, 2011, 10:22 PM   #3
GREASYHANDS
GREASYHANDS's Avatar
Frozen axle joints?
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old December 21st, 2011, 11:19 PM   #4
tweak177
Say what?!?
tweak177's Avatar
What vehicle are you asking about?
tweak177 is offline   Reply With Quote
Old December 21st, 2011, 11:29 PM   #5
VAhasnoWAVES
Dirty South
VAhasnoWAVES's Avatar
stock steering? i assume its for a cherokee by the tag you put...
what modifications do you have to begin with? CAs? track bar? etc...
if everything is tight, have someone get in the drivers seat and turn the wheel left and right while you try to identify the parts that arent functioning properly.
the steering box should have no play...
but id also check your track bar. they frame side mount is notorious for wallowing out and allowing the axle to move side to side. even a fraction of an inch, is enough to be felt at the wheel when going down the road. or the axle side mount could be loose/wallowed.
TREs... even if they are tight, make sure there is no play. youll see the drag link or tie rod doing some funky stuff.
check your wheel bearings and ball joints (crudely) by doing the "12 and 6 and "9 and 3" test. grab the wheel at those points, and rock it with the vehicle off the ground. there should be zero play.
these are all things you can do for free, without consuming much time. try to identify the problem before simply throwing money at it. start there and report back.
a note on everything being "tight," make sure its to spec, not "as fucking tight as i can get it," this is to properly set preload on your bushings increasing their life and letting them function properly.
VAhasnoWAVES is offline   Reply With Quote
Old December 21st, 2011, 11:31 PM   #6
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Wandering and notchy make me guess that the steering box may be an issue.
Old December 21st, 2011, 11:40 PM   #7
tweak177
Say what?!?
tweak177's Avatar
I was thinking the U-joint in the intermediate shaft.
Old December 22nd, 2011, 03:01 AM   #8
jcd302
jcd302's Avatar
You can grab the steering shaft @ the box and see there is a little play before the pitman arm moves.
Someone said there is adjustment on the steering box. I am going to look into that.
I am looking for XJ/Jeep specific issues. I know my way around, but have owned Fords for years and this is my 1st Jeep. Things like the trac bar wallowing out on the frame side, I'll look into that.
Old December 26th, 2011, 11:27 PM   #9
kristavsmichigan
Jeep Girl
Time for Durango box upgrade !
kristavsmichigan is offline   Reply With Quote
Old December 27th, 2011, 12:02 AM   #10
computeruser
computeruser's Avatar
Unless that isn't the problem, as has been suggested above...
computeruser is offline   Reply With Quote
Old December 28th, 2011, 12:30 AM   #11
jcd302
jcd302's Avatar
So a Durango box is a bolt on?
Old December 28th, 2011, 12:54 AM   #12
kristavsmichigan
Jeep Girl
I didn't have a issue with my stock one but read the Durango one was a better fit. The moment I put it on my whole jeep drove x100 times better. It's a direct match to a 98 TJ. ( sorry I can't remember if it fits all years) but you just take the pitman arm off durango box ( 97-99??) and put your jeep one on and it mounts right up. Make sure not to get the one that has steering stops..
http://www.jeeps-offroad.com/article...conversion.php
Old December 28th, 2011, 05:47 AM   #13
curbdog17
Mini Van
curbdog17's Avatar
did this help when your steering was wondering?
Old December 28th, 2011, 09:54 AM   #14
87mopar
Web Wheeler :(
87mopar's Avatar
I had the same problem. I ended up buying a lower steering shaft (the one that runs into the box). It was about $200. Mine had a lot of slop in the joint.
"Insert Comedic and or ego boosting quote questioning another members sexual orientation here"
http://www.greatlakes4x4.com/imageho...60bd7ea6d9.gif
87mopar is offline   Reply With Quote
Old December 28th, 2011, 02:29 PM   #15
jcd302
jcd302's Avatar
Does the Durango box work on the XJ (Cherokee)?
My box is the culprit. The steering with 'catch' slightly on occasion and seems to be loose on the right side.
Old December 29th, 2011, 07:41 PM   #16
9xjsport7
Hatin' In My Free Time
9xjsport7's Avatar
[QUO
TE=jcd302;2899507]Does the Durango box work on the XJ (Cherokee)?
My box is the culprit. The steering with 'catch' slightly on occasion and seems to be loose on the right side.[/QUOTE]
Yes it will fit the cherokee...seach over on cherokee forum their is a write up on it.....i believe you get a 98 Durango box that is without snowplow option but cant remember for sure.
9xjsport7 is offline   Reply With Quote
Page generated in 0.45025 seconds with 71 queries
