Just another Highline TJ*update tummy tuck* - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 9th, 2012, 11:01 AM   #41
mudrunner456
mudrunner456's Avatar
Originally Posted by hotwired View Post
I've read that before too, apparently there are some bosses on the rubi t-case that aren't there on the regular case. If I have to use it I will, I get some rubbing once in awhile when I'm flexed out anyhow so it won't really hurt anything.
Well if you end up wanting some more room we could always trade t-cases. I'll even throw in a case of beer to sweetin the deal. Lol
mudrunner456 is offline   Reply With Quote
Old December 10th, 2012, 12:49 PM   #42
hotwired
Yeah four to one is nice in the rocks, but in the sand it's too low and high range is too high. Luckily I don't really like Silver Lake, or at least not all the morons that seem to over-run the place.
hotwired is offline   Reply With Quote
Old December 10th, 2012, 01:19 PM   #43
Mr.Green
I can levitate!
Mr.Green's Avatar
Needs more stinger.
Old December 10th, 2012, 01:46 PM   #44
mudrunner456
Gotta go during the week. Youll have the place to yourself. Let me know and ill head up there with you next summer.
Old December 11th, 2012, 12:23 PM   #45
hotwired
I'll do that.
Old December 11th, 2012, 12:30 PM   #46
bigyj
bigyj's Avatar
I'll do that.
Maybe I could even bring the 4banger and show you how its done
bigyj is offline   Reply With Quote
Old December 12th, 2012, 10:16 PM   #47
hotwired
I'm sure you would! LOL Wait, why am I laughing at that?
Old December 16th, 2012, 01:30 PM   #48
two_much_talk
sit down shut up and ...
two_much_talk's Avatar
is there a bushing between the tranny and the cross-member? I didn't see one, wasn't sure if it was just the angle of the pics.
Old December 16th, 2012, 01:34 PM   #49
two_much_talk
all I heard was I need bigger tires for the sand !
Old December 16th, 2012, 08:26 PM   #50
Modestmar00Xj
Show me the trails!
Modestmar00Xj's Avatar
Send a message via AIM to Modestmar00Xj Send a message via Skype™ to Modestmar00Xj
yeah good job man! looks good! i really like the fenders you made! i ran 35' on stock axles d30 & 8.25 on an xj for 4 years and never had any problems.
Modestmar00Xj is offline   Reply With Quote
Old December 16th, 2012, 10:36 PM   #51
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
Any fear of trans cracking? I've been planning on doing the same setup but have been reading of people having problem with cracking trans. I am going to run poly bushings on motor mounts and use poly mounts by frame on crossmember like you did. Wondering if it will be too stiff and when frame flexes it will be too hard on trans with not enough flex from poly mounts.
Old October 21st, 2013, 08:05 PM   #52
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Looks great. You've got some skills. Any updates?
Old October 26th, 2013, 01:33 AM   #53
mudrunner456
Thanks, i am in the process of building a set of wagoneer dana 44's for it. 5.13 gears locked front and rear. Hopfully be done and ready for install with in the next couple weeks.
Old October 26th, 2013, 06:52 AM   #54
Chop
Mischievous Badger
Chop's Avatar
Run a poly mount at the trans. The case will crack if you hard mount the tran and bushing at the frame..
Old October 26th, 2013, 11:10 AM   #55
mudrunner456
Yes. Definetly didnt solid mount it. I ran the poly bushings at the frame connections and a 5/8" thick piece of rubber i found at work under the trans and it has been working fine.
Old November 3rd, 2013, 01:02 PM   #56
mudrunner456
Default time for some updates
Been really enjoying the jeep except for one part. the 3.73 gears. Its not to bad in the mud and dunes but driving and crawling sucks. Heres some pics from over the summer at a mud bog my daughter and i took first place in in our class.
Old November 3rd, 2013, 01:07 PM   #57
mudrunner456
So i decided that it was time for some gears. I already had an 8.8 and a hp dana 30 that i had got and was saving for this reason. But after breaking an axle shaft i thought that maybe dumping a grand into a dana 30/8.8 combo was a mistake. So i found this bad boy on craigslist and my mind was made up.
Old November 3rd, 2013, 01:08 PM   #58
Rob the plumber
Looks awesome. Congratulations on the win too.
Sent from my SM-N900T using Tapatalk
Old November 3rd, 2013, 01:19 PM   #59
mudrunner456
I got the axles back from having gears installed yesterday. so its time to start pulling mine apart. I am running 5.13's with 36's. welded rear locked front. Hopfully this will be noticably better then what i had.
out with the old
table full of parts
Old November 3rd, 2013, 01:20 PM   #60
mudrunner456
thanks. my little one is 4 and she thought it was awesome that we got that big check and our pics taken. I put it on the wall in the garage and everytime she sees it she asks if remember when she won the mud bog.lol
Page generated in 0.48330 seconds with 83 queries
