exhaust advice - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 17th, 2011, 08:22 PM   #1
mrkt
Default exhaust advice
Hey I was wonderin if anyone had any suggestions for exhaust. I have a 91 ford with a swapped out 460 I was going to run straight out 3 inch duals right now it is run 3 inch to under the cab but then a friend of mine told me with a stick it is good to have some back pressure so I was wonder if I should run a foot long 2inch or 2.5 inch section on both or just stick with the 3 inch? I have Like no money to spend on this so mufflers aren't an option.
Thanks any opinions are appreciated .
mrkt is offline   Reply With Quote
Old December 17th, 2011, 08:57 PM   #2
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
I've never had an issue due to lack of BP. I run 3" on everything I own. An engine is just a big air pump. more flow in / more flow out and vise versa.
The only back pressure that should be there is right at the exhaust manifold or header. That small amount is there so that you don't burn exhaust valves.
Maybe someone will chime in on the need for some, but I've never had an issue with it from carbed to injected motors.
Old December 17th, 2011, 09:10 PM   #3
skife
skife's Avatar
backpressure = automotive myth
Old December 17th, 2011, 10:16 PM   #4
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
I've heard this and I think I agree.
Old December 17th, 2011, 10:33 PM   #5
bigblockford79
Big Block Ranger
bigblockford79's Avatar
You might want to find some sort of muffler. My tow rig has a 460 with 2.5" pipe and mufflers and it is rather loud, especially when the secondaries are open. I am changing it soon to quiet it down considerably. Without mufflers on a BB you might get some unwanted attention from LEO as well. Thrush welded mufflers are only $35 ea, and sound pretty good as well.
Old December 18th, 2011, 02:13 AM   #6
skife
skife's Avatar
you know i'm curious, do you drive the black long box ford on 35"s that is loud as fukc ?
just checked, you are, howdy neighbor, I look out my window and can see your truck parked in the neighbor's driveway.
Old December 19th, 2011, 11:19 PM   #7
mrkt
Yes Sir. Are you the guy with the k5 blazer and jeeps? Sorry if I woke ya up.
Old December 20th, 2011, 12:12 PM   #8
skife
skife's Avatar
yep, i've got the K5, its currently in storage the tranny is boned, i'm looking for another jeep, right now i'm driving the shitty minivan.
Old December 20th, 2011, 12:53 PM   #9
mrkt
Oh well that sucks you did a sas to that right? (the k5)
Old December 20th, 2011, 01:14 PM   #10
Freak
Wheelin the HD
Freak's Avatar
Strait pipes are for fagots that are compensating. You might as well put upright headers through the hood so you can be king of the mud bog, but I don't want to hear your god damm truck every time you drive by.
Old December 20th, 2011, 03:27 PM   #11
mrkt
Wow next time i post I better check who's on their period.
I was looking for advice not douche bags.
Old December 20th, 2011, 08:23 PM   #12
skife
skife's Avatar
nope, K5s are all solid axle in the front (unless 2wd) and XJ's are all solid axles
welcome to greatlakes4x4
Old December 20th, 2011, 08:29 PM   #13
mrkt
Oh. Learn somethin new everyday. I like that green cherokee though.
Old December 20th, 2011, 08:53 PM   #14
skife
skife's Avatar
i've never had a green one, mine was black with huge holes in the doors.
Old December 20th, 2011, 08:56 PM   #15
mrkt
maybe I just have bad eye's lol. That red chevy doesn't look to bad either
Old December 20th, 2011, 08:59 PM   #16
dreezy
Haggard Fab
dreezy's Avatar
Don't be wt. Put some mufflers on it.
Old December 20th, 2011, 09:17 PM   #17
GREASYHANDS
GREASYHANDS's Avatar
To much backpressure is a bad thing. No myth about that.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old December 20th, 2011, 09:20 PM   #18
skife
skife's Avatar
thats the brother's truck
6.0 HD 3/4 ton... it'll be used to pull his 93 chevy when its done.
Old December 20th, 2011, 09:45 PM   #19
mrkt
well ya to much back pressure is a bad thing then the engine can't breath but is a little back pressure better than none at all.?
Old December 20th, 2011, 09:57 PM   #20
GREASYHANDS
The manifolds should create all the backpressure needed. Mufflers would be nice too.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Page generated in 0.31395 seconds with 83 queries
