Project: 1 piece at a time, 5.3 powered 1 ton Toyota. - Page 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 4th, 2013, 11:42 AM   #121
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Oh well then you still wont be able to turn 2 wd does not help at all when welded. Your still turning both front tires at the same speed no matter what.
Make sure your shafts are phased (lined up) when building your front axle or you will never turn
Mr. Beefy is online now   Reply With Quote
Old March 4th, 2013, 12:57 PM   #122
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
That doesn't sound like something i want to deal with....looks like i will be affording a lunchbox locker like i currently have one way or another
Old March 4th, 2013, 01:35 PM   #123
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Good choice
Old March 4th, 2013, 08:20 PM   #124
KennyOffroad
Ridge Runners Offroad
KennyOffroad's Avatar
Lunchbox locker is a Good choice
I have both F\R axles with Powertrax Lock-Right lockers.
Old March 4th, 2013, 08:31 PM   #125
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
My current axles have a lockright up front and the rear is welded....i am completely happy with it so i'm gonna set the new axles up the same.
Old March 5th, 2013, 09:48 AM   #126
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Picked up the 78-79 shafts i needed last night and dropped the housing off at the machine shop....i was gonna swap it myself but for what it will cost to have it done i can't justify messing with it.
Old March 14th, 2013, 06:15 PM   #127
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Been making a list:
Front: shooting for 31.5 spring width....axle mounts will likely have be custom, atleast on the passenger side, i am reusing my front hanger and modding it since it would be a giant pita ass to remove it, using sky's offset shackles and stock frame mounts, buy some shock tabs and reuse current upper hoop mount
Rear: sky spring mounts set to current width, shock tabs, reuse everything else.
Brakes:
Stock ford front stuff, ruffstuff rear bolt on disc conversion brackets and buy brake components local, reuse current hoses and adapt as necessary.
Steering:
Keep at stock height till i can afford better knuckles, hydro assist using current tapped box and tsc ram, fab mounts.
Drive shafts: high angle and sky both make 60 ----> Toyota flanges, Jesse at high angle says he can build me a sterling to Toyota flange as well. Keep current drive shafts and alter length as needed.
It all seems pretty straight forward....anybody see any glaring issues
Old March 25th, 2013, 11:33 AM   #128
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Ordered rear gears and master install, disc brake brackets, spring perches and diff cover.
Also ordered both pinion flanges from high angle....very good guys to deal with, quick turn around on what is basically a custom piece as well....definitely recommend them for anyone looking for drive line parts.
Old April 9th, 2013, 03:08 PM   #129
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Had a little trouble getting parts from ruffstuff but did finally get them....rear axle should be mostly done this weekend.
Got the front back from the machine shop and it turned out pretty good....tore it fully apart and i am currently working on plating the upper half of the knuckle with .25 plate since i can't afford after market knuckles.
Also my buddy gave me about 1/2 enough stuff to link the front with custom radius arms so if i can find some cheapish air shocks i am gonna do that.
Old April 9th, 2013, 09:42 PM   #130
generalyota
generalyota's Avatar
The extra width is gonna make is so much more stable, I want to go one tons eventually.
generalyota is offline   Reply With Quote
Old April 10th, 2013, 04:08 PM   #131
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Its wide as is (61" wms....80" outside of tires) so its already really stable. I plan on using rims with a fair amount of backspacing to try and keep the overall width down....ideally i would like to see the overall width only grow to 83-84" but we will see how it ends up
Old April 20th, 2013, 11:32 PM   #132
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Final trip on Toyota axles was awesome.....pushed it through some of the toughest stuff Rausch Creek has to offer.....truck worked flawlessly.....handled everything right in stride....no broken parts that i know of.....ready to swap axles and get back out on the trail!
Old April 21st, 2013, 08:57 PM   #133
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Couple pics...should have more soon
Old April 22nd, 2013, 11:09 AM   #134
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Old April 24th, 2013, 03:13 PM   #135
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Old April 25th, 2013, 08:01 AM   #136
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Rear is pretty much done. As for the front i have or have on order:
5.38's
Spartan
16" swayaway coilovers with triple rate kit
1.25 heims and brackets to build a custom radius arm setup
Trail gear orbital and tsc ram for full hydro
Should be fun getting it all to fit while keeping the truck low....i am shooting for around the same ride height but we will see
Old April 27th, 2013, 06:22 PM   #137
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Did a bunch of measuring.....it looks like if i remove my a/c compressor, move the axle ahead a couple inches, and slightly clearance the frame i can stuff the axle right up into the engine compartment and keep 6+" of uptravel while keeping the same ride height....one of the advantages of a tiny engine lol...if it comes right down to it i can lift the drivetrain some too.....i am gonna end up attaching the trac bar to the frame on the passenger side and the axle on drivers since it will be easier to package
The rear axle fought us setting up the gears but it will be buttoned up tomorrow.
Bought a piece of 3/8 x4 bar today to build a truss....gonna truss it from c to c over the top of the diff....also got enough 1/4 plate to fill in the space between the truss and tube for added support
Old April 29th, 2013, 10:07 PM   #138
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Rear axle all done
Also i forgot about this....i sold my tires and wheels and delivered them at rausch creek... had to put it on rollers to come home....those are 27" tall 1983 bias trailer tires lol
Old May 5th, 2013, 09:50 PM   #139
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Weekends progress....rear is all tacked together and sitting on its own....waiting to see where final ride height ends up before setting final pinion angle and burning it together....only issue i see is i may have to move the gas tank as the driveshaft may hit it. Got the front all stripped down and ready to start building. I put the housing under it and started mocking it in....it look like i am gonna be at 6" up, 10" down....its gonna get really close to the oil pan going up but i think i can fit it.....going down its gonna get close to the limit of the stock cv....if its too bad i am gonna order a dual case adapter and put the duals in to move the output back then i know it will work. Looks like wheel base is gonna be 119-121"
Old May 6th, 2013, 11:22 AM   #140
KennyOffroad
Looks Good !
Page generated in 0.44152 seconds with 84 queries
