Project: 1 piece at a time, 5.3 powered 1 ton Toyota. - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 9th, 2012, 11:39 AM   #61
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Dipstick? Crank seal would leak when running (oil pressure)
Old July 9th, 2012, 11:50 AM   #62
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Dipstick is dry. Leak is cocentrated in lf area of engine. The oil pump is up there (its external), crank seal, timing cover, and thats about it.
Old July 10th, 2012, 10:18 PM   #63
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
After degreasing and removing 18 layers of crap I found an interesting surprise....it looks to me like the timing cover, oil pump, water pump, ect,ect was all replaced in the not so distant past, which is great.
The leak is coming from behind the water pump where the timing cover, head and block all come together. A quick bit of research shows that when doing a timing set it is critical to apply liberal amounts of rtv to these corners along with the gasket in order to seal them up. My guess is that was not done. Looks like I get to pull it apart and reseal it all.
Old July 13th, 2012, 10:33 PM   #64
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
here is what I found after tearing it apart:
The timing components are definately new, the chain, guides, ect show zero wear....not only that but there are paint marker numbers and writing on the crank, block ect like the whole engine was gone through
Oil pressure has always been less than awsome....i found the pickup screen clogged with silicon.
Who ever did the timing components used the wrong type on silicon as it was amost chunky...no wonder it leaked.
I just lovr fixing other peoples hald ass work
Old July 14th, 2012, 08:43 AM   #65
Dave Kerwin
web wheeling, hard.
Dave Kerwin's Avatar
It's a good thing you decided to crack the chest on it, good confidence moving forward when you're done!
Old July 14th, 2012, 09:20 AM   #66
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I didn't have much choice....it leaked BAD and was getting worse. It runs good and has good power for what it is...it has no issue spinning 38.5's .....you are right though....i'm gladi found that pickup tube!
Old July 17th, 2012, 09:23 AM   #67
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
So something was not adding up when I was putting it back together....there was no gasket for the part of the cover that was leaking...i got to looking and apparently the head gasket is suppose to extend beyond the block and cover the timing cover too but someone cut that portion off...so now it needs a head gasket...dam it
Old July 17th, 2012, 11:52 AM   #68
roll-bar Bob
roll-bar Bob's Avatar
that sucks
when you got the cam in your hand, "replace it" with the right cam those 22r motors run like a 2 stroke
Old July 22nd, 2012, 09:34 PM   #69
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I patched it together...i didnt replace the headgasket since the main part of the gasket is perfectly fine and doing its job it seemed overkill to tear the motor apart and replace it. I got the oil leak to stop 99% of the time and when it does leak its very very slight and for a trail only rig thats good enough for me.
Looks like i'm gonna be going to rocks and valleys early august and the 3 more days at windrock over labor day. Can't wait. I love wheeling this thing!
Old July 23rd, 2012, 09:34 PM   #70
generalyota
Ridge Runners Offroad
generalyota's Avatar
the oil pick up was full of rtv on my 22r when I rebuilt it also. a huge p.i.t.a! i estimated there were at least 34 full tubes of rtv used on that engine when i tore it down.
generalyota is offline   Reply With Quote
Old August 7th, 2012, 11:49 AM   #71
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Went through and checked things over last night i preparation for bundy hill sunday....every thing looked good except:
How are you suppose to keep shackles tight?
This is my first leaf spring rig and no matter how often i tighten the darn things they loosen right back up after one ride. They don't get to the point they fall apart....just get to where the nuts are about finger tight and thats whee they stay
Old August 14th, 2012, 09:04 AM   #72
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Did great at Bundy Hill.....i tried hard to get it to leak oil and it wouldn't which is great. Windrock again in two weeks for ttora's south east take over with about 30 other built Toyotas.......can't wait!!!
Old August 14th, 2012, 09:07 AM   #73
h20son
h20son's Avatar
Send a message via AIM to h20son Send a message via Yahoo to h20son
its gonna break, cuz its gay
h20son is offline   Reply With Quote
Old August 14th, 2012, 08:00 PM   #74
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
It may break.....if it does i will figure out why and go from there. I am pretty happy with it right now.....it has came a long ways since i drug it home.
Old September 3rd, 2012, 07:56 PM   #75
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Some fresh pics from windrock this weekend....truck worked flawlessly
Old September 3rd, 2012, 09:44 PM   #76
generalyota
that place looks killer!
Old September 4th, 2012, 07:28 AM   #77
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I am starting to really like the place....it is huge and confusing at first but once you get tge basics of where to go down it is a awesome place to wheel.
Old September 5th, 2012, 05:54 AM   #78
generalyota
how far of a drive is it from bc or kazoo?
Old September 5th, 2012, 07:52 AM   #79
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Its 1050 miles round trip (i live on the nw side of bc) i have been down there twice this year and can't wait to go back.
Old September 5th, 2012, 07:52 PM   #80
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
The few times i have used the winch i have realized that steel winch cable sucks so i picked up 100' of 3/8 synthetic line, a aluminum fairlead, and rubber isolater
Page generated in 0.33152 seconds with 84 queries
