Project: 1 piece at a time, 5.3 powered 1 ton Toyota. - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 29th, 2012, 08:28 PM   #41
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Gave it a very solid shakedown this weekend down in wellsville ohio....all I can say is wow!!....this thing straight up works....need some odds and ends still but it will go.almost anywhere I point it
I had to winch that ledge...i hit it a couple times in first gear sort of easy and it tried to climb but wouldnt quit do it...i think if I would have grabed 2nd and hit it like I ment it it would have went up it....i did not do it since we were only half way through our first day and I did not want to chance it so I pulled cable...here is a 1 ton tj on 40's at the base of the ledge to give you some perspective of the size
Old April 29th, 2012, 08:43 PM   #42
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
That water fall was awsome...it was longer than my wheelbase, steep, and slippery as hell...it is a solid sheet of rock covered in muddy water...of the five in our group I was the only one to drive it without cable...started about 2' from the bottom and hit it 3rd gear, foot on the floor...what a rush!!!
Old April 29th, 2012, 09:12 PM   #43
Streetkill831
Sick rig man! Old school paint is really cool.
Streetkill831 is offline   Reply With Quote
Old April 29th, 2012, 09:54 PM   #44
BLZR
BLZR's Avatar
Lookin' good Todd! I need to make it down there next year
BLZR is offline   Reply With Quote
Old May 4th, 2012, 04:20 PM   #45
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Starting to plan for the rear coil conversion. I am happy with the front leaf springs but the rears suck. I am gonna do a triangulated 4 link with heims and coils. Simple, solid, nothing bling or fancy.
My question:
Do I stay with the standard 8" toyota rear axle or step up to the ff 9.5" fj80 rear? I would gain strength, discs and ff but parts are more money and I am not breaking what I currently have.
My thought is to step up since I want to do a 3.4 v6 swap in the future.
Old May 15th, 2012, 07:56 PM   #46
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Bought everything I need to build a new rear dshaft out of 2 1/2" sched. 40 pipe (~.25 thick) since my current one is bent. Also picked up a new steering box since my current one was drilled / tapped for the hydro assist incorrectly by the po and I cannot keep it seeled.
Old May 23rd, 2012, 08:38 PM   #47
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Built the new drive shaft and put it in. Also took the old steering box out...apparently that thing is fucked lol. If I grab the input shaft with my hand I can turn it and turn the pitman arm. However if I grab the pitman arm I can not turn it...it is bound tight....that may explain why it steered funny and always leaked
I got a new box all drilled and tapped just gotta put it in.
Old May 24th, 2012, 10:33 PM   #48
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Put the new steering box in....also took the old one apart...the worm gear in the input of the old one is 90% stripped....its a miracle it steered at all. Also buttoned up some loose ends and pulled the doors....ready for bundy sunday!
Old May 24th, 2012, 10:36 PM   #49
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Thought this was a neat pic for size comparrison...side by side with my stock tow rig on 33s
Old May 28th, 2012, 02:50 PM   #50
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Worked great all day yesterday at bundy hill....gonna give it a good once over then its off to windrock next month.
Old May 28th, 2012, 02:54 PM   #51
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Old May 28th, 2012, 10:05 PM   #52
generalyota
Ridge Runners Offroad
generalyota's Avatar
when we do our local run in south haven next month, bring it out so I'm not the lone yota in a sea of jeeps!
generalyota is offline   Reply With Quote
Old May 28th, 2012, 10:28 PM   #53
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Keep me posted as to when it is....i am headed to windrock next month so I may not be able to fit in another run but I will try
Old June 8th, 2012, 09:46 AM   #54
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I plated and insured it the other day since there are times I may need to street drive it...i took it for a drive and much to my surprise it drives very nice...with some smaller, radial tires you could easily dd it, or drive it to and from wheeling events.
Gonna give everything a check over / retorque and then its off to windrock thursday.
Old June 11th, 2012, 10:47 PM   #55
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Thumbs down
Checked it all over and it is all holding great. Everything is holding torque which is a big key to.keeping these axles alive with big tires....stuffs gotta stay tight. Did find a broken hub dial gear which dont surprise me...looks like drive flanges are in my future.
Old June 12th, 2012, 08:47 AM   #56
generalyota
I would upgrade the rear axle if you do a 3.4 swap. The ring and pinion are not friendly with horsepower. Plus the width of the fj80 axle would be nice. I know a great place to purchase coil springs alot cheaper than most other places also.
BTW that place in Ohio looks incredible! What is the name of the place?
Old June 12th, 2012, 09:15 AM   #57
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Its called wellsville or yellow creek....its kinda a locals only spot....if you ever want to go I will round up some locals and we will set up a trip.
We ( ohttora) have a event there every spring....its alot of fun
Old June 12th, 2012, 09:20 AM   #58
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
A bunch more pics
Wellsville, OH 4/27-4/28 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 17th, 2012, 10:13 PM   #59
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Smile
Spent friday / saturday wheeling windrock in tn. Truck worked ok and nothing broke that I see...however there are a few things I want / need to address
1. It needs to flex better for the reallt hard stuff....i think the issue revolves around the rear suspension so thats where i'm starting.
2. I need dual cases.....single 4.7 low sucks
3. Bunch of minor random crap.
I did beat on it pretty hard a couple times and it held great so what I dis already works....just need to keep going.
Old July 9th, 2012, 11:48 AM   #60
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Gonna try to sort the oil leak out tonight.
Back story: it has had a mild-moderate oil leak from the front of the engine since I got it...i never worried about it...then in windrock while going down a super steep hill it basicallypouring oil out....it only did it going down reall steep hills....it leaked down to about 1/2 - 3/4 qt low and stopped. It has sat in my garage unmooved since I got home with no spots under it.
I am thinking its the crank seal....any other thoughts.....my plan is to fill it with oil, clean it really good, then let it run while somehow elevating the rear end and watch for the leak to start.
Page generated in 0.36402 seconds with 85 queries
