Project: 1 piece at a time, 5.3 powered 1 ton Toyota. - Page 16 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 2nd, 2014, 02:28 PM   #301
yota85
yota
yota85's Avatar
Sounds like decent customer service.
yota85 is offline   Reply With Quote
Old April 6th, 2014, 07:16 AM   #302
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Got my new tie rod installed yesterday....1 5/8 solid hexagonal bar stock. I wanted a fancy 7075 aluminum unit but by the time i got a tab on it for the ram it was going to be ridiculously expensive....i am into this for 25$ so it will have to do
Old April 6th, 2014, 03:53 PM   #303
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Installed picture....it's a tight fit but clears
Old April 27th, 2014, 05:50 PM   #304
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Some videos and pictures from the badlands....truck worked great!
https://www.youtube.com/watch?v=x5pY...e_gdata_player
https://www.youtube.com/watch?v=jVYg...e_gdata_player
https://www.youtube.com/watch?v=N1g7...e_gdata_player
That last one sucked....that hill was nasty steep and full of loose dirt and cement.....i went bombing up it and crashed into that 20' deep sinkhole....i know it doesn't look like it but the truck is actually laying on the drivers door...i was able to back out of the hole luckily but i couldn't back down the hill do to being at a terrible angle...luckily i was able to work the front end over and straddle the hole very carefully
Old April 28th, 2014, 02:19 PM   #305
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I am a little disappointed with these new rims....they seem to not like to hold the inner bead and i think the inner is burping air.....never had either issue with the old rims
Old April 28th, 2014, 02:33 PM   #306
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Boo! I installed an inner airlock on a rim last week, and wheeled with them this weekend. If I have that problem with my new racelines I'll be putting Inner Airs in them.
Old April 28th, 2014, 02:40 PM   #307
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
At 10-12 psi they seem to be ok for the most part so that's good. I would like to run them at 7-8 psi but if you do that then you start having issues. If these tires were 17's i would save up for some stazworks double beadlocks and call it good but they are 16's which are pretty much obsolete so i am not gonna drop that kinda cash on rims....especially since i would like a different set of tires eventually and they are only available in 17's
Old April 28th, 2014, 07:11 PM   #308
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
One more pic....i really like this one
Old April 30th, 2014, 08:50 AM   #309
KennyOffroad
Ridge Runners Offroad
KennyOffroad's Avatar
Nice pictures and videos.
Sent from my DROID RAZR using Tapatalk
Old May 31st, 2014, 08:11 PM   #310
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Had a good time at silver lake today.....truck did absolutely terrible just as i suspected it would lol. Actually it bombs through woops pretty decent, just don't try to go up any hills lol. I did notice it's spitting out a crap load of fluid from the tcase when i was strapping it down on the trailer.....not sure what that's all about.
Old June 22nd, 2014, 08:22 PM   #311
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Fun day at bundy hill today. After silver lake the transfer case didn't leak at all in the garage so i thought maybe it had just gotten hot and was just spitting it out the vent so i didn't do anything to it before today.....well now it is running out non stop .
Today was real smooth until we got to warn valley....was smoking it till about the 3/4 mark when the truck just died and wouldn't restart....after lots of head scratching we finally figured out that the coil wire had rubbed though and was shorting out....little electric tape and she fired right back up and drove right on through.
Old June 22nd, 2014, 09:56 PM   #312
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
All in a good day of wheeling.
Old June 23rd, 2014, 08:55 AM   #313
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I just hope the transfer case is something simple. I hate to dump a bunch of time and money into it just to pull it in a couple months. My fear is it has smacked the trans tunnel one too many times and has cracked the case.
Old June 23rd, 2014, 06:44 PM   #314
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Looked at it tonight....it's leaking where the two halves of the case bolt together....this lead me to discover that none of the bolts were tight. So best case scenario i tighten the bolts down good and it stops or at least slows to a seep....worst case i have to pull it (not fun) take it apart and reseal it.
Old June 23rd, 2014, 07:39 PM   #315
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Bonus!
Old July 9th, 2014, 08:00 AM   #316
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Fun day at Rocks and Valley's. The transfer case leaks less....but still more than i care for....i gotta get it cleaned up better but it looks like the front output seal may be blown. Time to give it a good once over ans get it ready for Harlan over labor day!
Old July 20th, 2014, 04:42 PM   #317
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Got bored today...the cage was beat and starting to rust so it needed paint....i was wanting a darker orange but it turned out bright
Old July 20th, 2014, 08:11 PM   #318
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Turned out nice! I have been thinking of changing my cage color also.
Old July 20th, 2014, 10:15 PM   #319
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
It sucked trying to paint it on the truck
Old August 31st, 2014, 08:22 PM   #320
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Not so great trip to Harlan....3/4 of the way through day 1 of 3 i managed to break a short side inner which i didn't have a spare for (who breaks a 60 with a 75 hp 4 cyl).....searched every where for a replacement with no luck so i packed it in and came home a day early after spending day 2 sight seeing in 2wd
Page generated in 0.27668 seconds with 84 queries
