Project: 1 piece at a time, 5.3 powered 1 ton Toyota. - Page 12 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 11th, 2013, 08:42 AM   #221
crunchedtj99
my plan is th350/205 and i have just accepted stupid low axle gears. i like high wheel speed wheeling but im going to be running 37's with 5.13's so that low range calculates out lower than my ax5 231 setup on 35's with 4.10's is currently. and 4 high ends up right between my current 4 low and 4 hi in my xj. which is perfet cause currently 4 hi is totally useless
crunchedtj99 is offline   Reply With Quote
Old December 11th, 2013, 09:27 AM   #222
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I am too poor for high wheel speed wheeling......my current crawl ratio is 100:1 which is nice but too low for my only ratio....the nv4500/205 will be ~60:1 which should be nice with the new power.
Old December 11th, 2013, 10:42 AM   #223
crunchedtj99
wow u are low right now.
im currently at 44 low 15 high lol
350/205/5.13 puts me at 25... holy crap time to rethink this plan..... id love to be around 15-20 in high and around 55 in low
i must have calculated it using the 3:1 low range ive been seeing as an aftermarket option for the 205 but dang its expensive. i think at this point i may just adapt my 231 to the th350 and run it for now.
okay back to the drawing board on that one
Old December 11th, 2013, 10:54 AM   #224
koochman450r
koochman450r's Avatar
Yeah you can always put a 700r4 first gear in your 350 and it'll take it down to about 30 for you crawl ratio. Even with a doubler and stock th350 gears you would be at like 60. With more power and an automatic you don't need as low of a crawl. Plus v8s don't rev to the moon like the 4cyl do. However my ranger is 100:1 and I love it. And I can still pull midrange good with the 4.10 and 36's. High is ok for around town. Planning on a sbc swap soon and I think i'll have to use a doubler. I love the midrange.
you won this battle.
koochman450r is online now   Reply With Quote
Old December 11th, 2013, 11:40 AM   #225
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I know what your saying....i have just got really use to the way it is and it works great for me....or it would with more power.
Decisions decisions
Old December 11th, 2013, 11:48 AM   #226
crunchedtj99
true todd you climbed real nice and smooth even on the old setup. i kinda like the ratios im seeing with the 700 first gear and using my np231. sad part is ill need a different front axle
Old December 11th, 2013, 12:50 PM   #227
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
It's smooth.....it just runs out of power.....going from 100hp to 300hp will fix that. I just bought a 4500. Gonna stick with what i know.
Old December 11th, 2013, 02:02 PM   #228
crunchedtj99
i just adapted my stick to work kinda nicely. for this summer the most likely conclusion is switch to the toyota trans and tcase that i have for the little bit better low range. i am really beating on it hard right now to do some of the hills im attempting. so switching running gear and axles to the 5.13's even if i keep my weenie 4 cyl should make it crawl much more better
Old December 29th, 2013, 06:04 AM   #229
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Picked my nv4500 up yesterday. Having a little trouble finding a 205 but i am sure i will come up with one.
Looks like i will be stuck changing oil pans to a shallower one and swapping to a car intake to get the motor to fit like i want. The oil pan is no big deal since i wanted a baffled steel pan anyway but the intake sucks....from reading it seems ls1 intakes suck and will cause the motor to loose hp/tq so i was looking at ls6 intakes which are $$$....i wish the dam truck intake would just fit
Old January 20th, 2014, 09:39 AM   #230
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Finally found a reasonably priced round pattern gm 205
Will be doing intake, exhaust manifold and oil pan swap in the next few weeks so motor is dressed and ready to go. Trans is ready to go. Gotta swap inputs in the tcase and order a clocking ring the i can attach it to the trans. I am also about 95% set that when the engine swap happens the entire body structure in front of the cab will go away and be replaced with tube. Something like this
Old January 20th, 2014, 10:00 AM   #231
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Copy cat
Old January 20th, 2014, 11:40 AM   #232
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I know
At some point i also plan on removing the entire rear half of the truck as well
Old January 20th, 2014, 03:42 PM   #233
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
More inspiration
Old January 24th, 2014, 03:03 PM   #234
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Picked up a ls6 intake/injectors/rails. One more piece of the puzzle.
Old February 5th, 2014, 10:37 AM   #235
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Looking into mounting everything...my big concern is supporting the heavy ass tcase....ran across this which looks like it would work perfect for me. Thoughts?
http://www.behemothdrivetrain.com/si..._PRODUCTS.html
Old February 5th, 2014, 10:41 AM   #236
Mr. Beefy
BFT!
Mr. Beefy's Avatar
I think I'm going to buy this one
Old February 5th, 2014, 10:43 AM   #237
http://www.pirate4x4.com/forum/bad-s...rivetrain.html
Old February 5th, 2014, 10:45 AM   #238
I bought tmrs. Had to modify it a little bit obviously to fit what I needed. I also had to change my fill plug on the case as it wouldn't work with the bracket.
Old February 5th, 2014, 10:55 AM   #239
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Well there goes that thought
Old February 5th, 2014, 10:57 AM   #240
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I would assume that the bolt pattern where that attaches is symmetrical meaning it will work with clock applications?
Page generated in 0.43370 seconds with 84 queries
