Project: 1 piece at a time, 5.3 powered 1 ton Toyota. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 17th, 2011, 08:17 AM   #1
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Default Project: 1 piece at a time, 5.3 powered 1 ton Toyota.
This is my trailrig. 85 toyota pickup, 22re, 5sp, single 4.7 case, 5.29's, aussie front, welded rear, rear springs up front, 63" chevy springs in back.
Old December 17th, 2011, 08:33 AM   #2
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Its a rust free southern truck, I got it from Tn built like this. Those pics are from it's first bundy hill trip. That trip showed a few issues. The biggest is the front tires hit the cage, bind, and snap the axle shaft, so that is being fixed.
I recently bought some longfield axle shafts, trailgears trunion bearing eliminator, knuckle rebuild kit, knuckle ball gussets, ARP steering studs as well as some other odds and ends and I have them almost in. Also have some cage work, planed as well as some other stuff as my wallet allows
Old December 17th, 2011, 09:02 AM   #3
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
One question I have. I want to get a fuel cell, I also plan to get a set of 35's so I can do some of the tt races in the small tire class, as well as maybe the dirt riot race in trail stock, things like that. I have been researching the and I am kinda uncler on exactly what I need for it to meet the rules. I want a aluminum one. Any suggestions on one would be appreciated.
Old December 18th, 2011, 07:25 AM   #4
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Started tearing into the front axle.
Got I tore down, clean and gusseted
Gonna work in it more today.
Old December 18th, 2011, 08:27 AM   #5
Dave Kerwin
web wheeling, hard.
Dave Kerwin's Avatar
I love the old graphics. Fun rig
Old December 19th, 2011, 02:47 PM   #6
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Worked on reassembly yesterday. Was doing good till I had a momentary lapse in brain function and screwed up one of my new steering studs.
A note on the trail gear trunion bearing eliminator, while I am certain it is a better, stronger setup, it is a royal pain in the ass to get shimed correctly. I tried about 20 different combos before I got it where it needed to be.
Old December 21st, 2011, 09:15 AM   #7
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
This is what I will be doing to fix the weak stock hub studs...seems to be stongest and cheapest solution.
7/16th Locking Hub Bolts - Pirate4x4.Com Bulletin Board
Here is how I plan to add the 5th bolt to the steering...going with grade 8 1/2". That and the arp studs should keep the steering attched.
toyota 5th stud steering upgrade - Colorado4x4.org Forums
Old December 22nd, 2011, 01:05 PM   #8
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
So far for this rebuild I have needed
8 studs
14 bolts
10 nuts
14 washers
Total price for said fasteners ~ 110$
I guess qualiy, somewhat specialized fasteners are exspensive LOL. Ohwell, quality parts are not worth dam if they are not securely attached so I guess it is worth it.
Old December 24th, 2011, 08:07 PM   #9
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Got a couple hours to work on it today. Get the rest of the old hardware out that is getting replaced, made brackets for my 5th stud and started drilling and taping for the hub studs. This pic shows the difference in the new and old. Shouls no longer have to worry about sheering them and I get to ditch the dam cone washers
Old December 24th, 2011, 09:37 PM   #10
curbdog17
Mini Van
curbdog17's Avatar
Nice build, I like it.
Old December 27th, 2011, 10:02 PM   #11
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Made more progress. 5th stud installed and well on the way back together
Old December 29th, 2011, 10:43 AM   #12
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
8]old power steering cooler, new one behind it
all plumbed
Old December 29th, 2011, 10:44 AM   #13
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Upgraded the power steering cooler.
Old January 2nd, 2012, 08:23 AM   #14
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Got the axle all back together and the truck back on all 4's. It should tollerate the 38's pretty well now.
Next up is some work to the exo to make it a little stouter and do something with the low hanging gas tank.
I know it's a little ghetto but, iş there any blatant safety issue with pulling the stock tank, spinning it 90*, then straping it down in the front of the bed under the cage. It is in great shape, would fit perfect, would be easy to plumb, and is already setup for the truck.
Old January 2nd, 2012, 08:26 PM   #15
h20son
h20son's Avatar
Send a message via AIM to h20son Send a message via Yahoo to h20son
looks like a POS, torch it, roll it down a hill and take it back for scrap, you'll never make it through deep mud holes without any lift like that
h20son is offline   Reply With Quote
Old January 7th, 2012, 11:17 PM   #16
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Fixed the cage today, should be well clear of the tire now, no more binding.
All I gotta do now is fix a steering fluid leak and she is ready for a shake down run.
Old January 8th, 2012, 05:38 PM   #17
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Got the leak in the steering fixed today and discovered a new issue...the amount of fluid required for the steering to work when running is larger than it will hold when off so when you shut the truck off it backfed and overflowed the resevoir. So out came the tools and I built a new high capacity resevoir out of 4" exhaust tubeing and parts of my old.one
Works great, no more overflow
Old January 8th, 2012, 05:45 PM   #18
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
At this point it is done till I get a trailer to haul it with, then I will be working on a few more things. I flexed it out on the only thing I could find and confirmed that the tires do now clear.
Old January 8th, 2012, 06:00 PM   #19
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I should also mention the previous owner left 3 mossyoak air fresheners, a mossy oak steering wheel cover, and a mossoak cd organizer in it when I got it. Those things make it hardcore right?
Old January 8th, 2012, 07:05 PM   #20
Elusive
Elusive's Avatar
Elusive is offline   Reply With Quote
Page generated in 0.29458 seconds with 85 queries
