Front pinion bearing 04 rubicon - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 16th, 2011, 05:37 PM   #1
Bishop
Bishop's Avatar
Default Front pinion bearing 04 rubicon
2004 Factory D44. Is the Front pinion bearing replaceable with out removing the differential?
I found mine to be loose while looking into a vibration that gets better in 4wd.
Easy fix or am I going to be tearing the diff apart?
Thanks.
Ps, any write-up out there? I came up with nothing.
Old December 16th, 2011, 06:51 PM   #2
GREASYHANDS
GREASYHANDS's Avatar
The bearing nearest the drive shaft yoke can be serviced without removing any gears. You must remove the pinion nut, washer, yoke and seal to get at it. However if you need to replace the bearing race aswell, you may need to pull the axle shafts and the carrier assembly to use a punch to remove the race.. A good slide hammer can pull the race with out removing the rest of the parts.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old December 16th, 2011, 06:55 PM   #3
dougstephvoor
Supreme Chancelor!
dougstephvoor's Avatar
http://www2.dana.com/pdf/5310-3.PDF
try this, it has been helpfull to me.
dougstephvoor is offline   Reply With Quote
Old December 16th, 2011, 07:10 PM   #4
Bishop
Bishop's Avatar
Thanks. What's the chances of just the outer bearing being bad, and not the inner?
Old December 16th, 2011, 07:15 PM   #5
alterego
alterego's Avatar
Default scientific calculation
dana 44 / driving condition + age of driver - average RPM while traveling
__________________________________________________ _______
(tire size) * (gear ratio) - amount of times the vehical has been placed into reverse = 75.24%
alterego is offline   Reply With Quote
Old December 16th, 2011, 07:32 PM   #6
shawn
Resident HVAC/R Jambi
shawn's Avatar
I'm overhauling my rear 44 because of a bad pinion bearing. Just take it all apart and do them both. Actually, just get an install kit and do it all.
Old December 16th, 2011, 07:53 PM   #7
Bishop
Bishop's Avatar
Thanks, does that include a new ring and pinion also?
Sounds like the jeep is going to be down for a weekend.
Old December 16th, 2011, 07:59 PM   #8
shawn
shawn's Avatar
No
Bearings, seals, and shims. You shouldn't need the shims.
But to price out 4 bearings and 3 seals will probably cost more then the install kit, so that's why I said just get an install kit.
Old December 16th, 2011, 08:22 PM   #9
GREASYHANDS
Thats some good math there.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old December 16th, 2011, 11:25 PM   #10
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
How bad are the bearings? How long have you drove on it? Depending on the answer you may not be able to get a good pattern after swapping in the new bearings.
A good way to check would be to check your pattern before you tare it apart, that way you'll know if you need to order gears or not ahead of time.
For the install kit check out the link in my sig, Ron has great prices, awesome customer service, and he's in MI too. Also he also sells package deals if you want to use this as an excuse for for a gear swap
Old December 17th, 2011, 09:15 PM   #11
shawn
shawn's Avatar
I know it's always a concern and something I hear and read people complain about, but I've replaced bearings on a few diff's (carrier and pinion) and never needed to replace the gears. Even if the pattern isn't exactly like it used to be, as long is it's still good there has been no concern. Got one vehicle with over 50k on it since I did the diff bearings and no problems.
Old December 19th, 2011, 10:55 PM   #12
Bishop
Bishop's Avatar
Thanks for the help Shawn. I'm going to try and tackle this next week. I'm sure I'll have more questions soon.
Page generated in 0.31098 seconds with 59 queries
