U-bolts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 16th, 2011, 01:11 PM   #1
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Default U-bolts
I need to replace mine as I re-used the dana 30 and dana 35 ones and just re-bent them in a jig I made to fit the 9" and dana 44...... That was 6 years ago
I went to a spring place here in Livonia and the guy said I should upgrade from 1/2" to 9/16" or 5/8" .. is this common? Its only $1 more per one.
Old December 16th, 2011, 02:18 PM   #2
rangerluc
rangerluc's Avatar
ive got 5/8" on my axles. its overkill but like you said, for an extra buck why not
rangerluc is offline   Reply With Quote
Old December 16th, 2011, 02:25 PM   #3
skife
skife's Avatar
6years ago? sounds like its fine to me
Old December 16th, 2011, 03:08 PM   #4
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Well sadly all they had was 1/2" stock So 1/2" is what I went with. I figure if they lasted this long without any issues I should be ok.
And 6 years ago on the stock u-bolts that I heated up, and re bent to fit the bigger axle tubes. I could not torque them down all the way because before hitting the mark, I could feel the threads stretching.
Old December 16th, 2011, 03:24 PM   #5
Strangler
Strangler's Avatar
I have a set that ARC bent for me for my black YJ, and then I linked it. You can have them for 1/2 of whatever they charge now.
Old December 16th, 2011, 10:41 PM   #6
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
For the record you shouldn't reuse U bolts. They fall under the same thing as head bolts, they get torqued to their yield and shouldn't be retorqued. Not saying you can't, just saying you shouldn't. I've never seen a retorqued one fail, but for my dd I got new bolts.
Besides they don't live a happy life under a MI rig with rust and the general abuse that we put them through.
Old December 16th, 2011, 10:42 PM   #7
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
ahhhh thanks scott but i already bought them and installed.
Old December 17th, 2011, 07:24 AM   #8
Strangler
Strangler's Avatar
Agreed, but these were only used for mockup, always loose for pinion adjustment.
Kirk, cool. Glad your all set.
Page generated in 0.20756 seconds with 47 queries
