Toyota Rear Full Floating Axle Flanges! - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old December 16th, 2011, 01:52 AM   #1
Gravel Maker
Steel Hauler
Gravel Maker's Avatar
Arrow Toyota Rear Full Floating Axle Flanges!
I held off making these items for a year because another vender made them and promised me a fair price when I needed them.
When I needed them his fair price turned out to be about 6 times what they cost to make. It seems he just wanted me out of the market for a year. Well, I guess he got what he wanted but I don't believe in false promises.
So here are the flanges that can turn your rear axle into a Full Floater and they are from Ruffstuff!
This is a weld on Axle Flange to mount Front Toyota Mini, Fj40, or FJ60 spindles to the rear axle. The caliper bosses are made to use the IFS Truck ('86-'95) calipers and FJ40 or FJ60 rotors.
These are 1" thick and made from 44W Plate & cutout for the 3.5" axle tube used our Axle Housings. We will release a 3.25" & 3" version in a couple of weeks. These are $195 a pair, not the $300 price I was quoted from the other vender originally...
[SIGPIC][/SIGPIC]
Dan Fredrickson
www.ruffstuffspecialties.com
916.600.1945
Your Fabrication Parts Source
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old December 22nd, 2011, 04:18 PM   #2
Gravel Maker
Steel Hauler
This makes a Full Floating rear axle easy, and a disc conversion atthe same time!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old January 4th, 2012, 02:33 PM   #3
Gravel Maker
Steel Hauler
These are getting really popular, 2 more sets out yesterday!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old January 10th, 2012, 10:38 PM   #4
Gravel Maker
Steel Hauler
Of the new items we have released over the last 3 months these are #2, only 1 is out doing it!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old January 19th, 2012, 06:50 PM   #5
Gravel Maker
Steel Hauler
Arrow
Here are some pics installed, they are on one of our 9" housings I am using in the rear of my FJ45 pickup...
Just the flange...
With the spindle...
With the Hub, Rotor, & Caliper...
Its really a pretty simple operation and this is just about all the instructions anyone will need. Of course I am running 31 to 30 spline shafts but they are damned easy...
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old January 20th, 2012, 01:59 PM   #6
Gravel Maker
Steel Hauler
Here are a couple of questions from another site that help explain these a bit better...
Originally Posted by snobdds View Post
I like this a lot. I like the ease of redoing full floating axles. Once the actual lenght of the inner axle is figure out, I might have to get me a set...keep us posted.
The axle should not really be too much of a concern. It would be great if you could use a used front inner axle but I would say build it to the length you want and don't compromise by building it to an existing part...
Originally Posted by RBX View Post
Since these are weld on flanges, what dies one do about the 4-bolt mounting area? In other words, what is the best way to center these flanges on the axle and weld to?
Originally Posted by RMA View Post
^good question..how do you true it all up....maybe a rod all the way thru the axle..
You would remove the 4 bolt flange, it isn't used any longer. You would be using double splined axles like front inners.
We install them using a trubar but a simple instalation trick would be to use a long (5') piece of heavy DOM or 3" angle iron and 2 machinist squares. Clamp it about 3" off the faceplate and setup the correct length and then with the machinist squares true them to each other. Pretty simple...
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old January 20th, 2012, 04:32 PM   #7
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
So do you have a standard length that is known to work when puting these on a ifs mini truck rear. Any idea what shafts would run $$ wise?
Old January 23rd, 2012, 11:35 AM   #8
Gravel Maker
Steel Hauler
I won't have that until we have the smaller sizes in and we can make one. The shafts are a little under $200 from Branik Motorsports for 4340 Chromoly...
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old January 25th, 2012, 10:23 PM   #9
Gravel Maker
Steel Hauler
Here is the finished front axle to go with it, I did not know for sure but I am happy to report that FJ40 and Mini Aisan lockouts are a direct replacement for the fulltime factory stuff! This is an 8" set up with Hellfire Fab's FJ80 Knuckles and High Steer!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old January 27th, 2012, 02:15 PM   #10
Gravel Maker
Steel Hauler
We got a ton of calls about the Hellfire Knuckles yesterday. They are the only reasonable way to add the strength of the FJ80 birfield with a good High Steer setup. We are the only distributor besides buying them direct from Billy. I haven't yet advertised them because Billy sold the first 45 pair in about 6 weeks, the next batch should be done in a couple of weeks.
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old February 14th, 2012, 12:37 PM   #11
Gravel Maker
Steel Hauler
These are a big deal!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old March 1st, 2012, 04:27 PM   #12
Gravel Maker
Steel Hauler
Time to do that rear axle right!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old March 24th, 2012, 03:02 PM   #13
Gravel Maker
Steel Hauler
We now have all 3 sizes in stock so you can use these on just about any housing, 3", 3.25", & 3.5" :)
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old June 10th, 2012, 02:09 AM   #14
Gravel Maker
Steel Hauler
When building a Toyota axle don't leave it as a semi floater with drums :)
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old October 17th, 2013, 11:45 AM   #15
Gravel Maker
Steel Hauler
If your going to do it, do it right the first time!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old November 5th, 2013, 10:53 AM   #16
Gravel Maker
Steel Hauler
Give your toyota axle what it needs!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old June 5th, 2014, 11:17 AM   #17
Gravel Maker
Steel Hauler
Keep those orders coming!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old June 22nd, 2014, 02:15 PM   #18
Gravel Maker
Steel Hauler
Do it the right way with full float axle flanges!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Thread Tools
Page generated in 0.26355 seconds with 77 queries
