TJ bumper - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 14th, 2011, 09:35 PM   #1
jeepxj2007
Send a message via AIM to jeepxj2007
Default TJ bumper
I built this for a buddy. Let me know what you think...he had a universal winch plate that didn't have any holes that lined up to a tj so I welded them all shut and then drilled them out to bolt up...then trimmed it up a little...then the main tube is 2x4x3/16" tube with drings welded to one side...we used 1.75x.120 wall tube for the hoop and grill guard....it may look like it is crooked depending on the angle of the picture...but I assure you its not...how did it turn out? D-rings, the winchplate, and the tube still needs to be completely welded to the bumper...underneath it also catches each frame rail bolt hole on the bottom as well. When its all done im going to grind the welds smooth on the main tube.
jeepxj2007 is offline   Reply With Quote
Old December 14th, 2011, 10:43 PM   #2
krowen
krowen's Avatar
can you bend tubing? if so what would you charge me to bend 2 pieces for my rock gaurds as as drop down step. Thanks Kim
krowen is offline   Reply With Quote
Old December 15th, 2011, 05:28 AM   #3
jeepxj2007
yes i can...I only have a 1.75 die right now though so thats what you would be limited to in size
Old December 15th, 2011, 08:08 AM   #4
Tab
Tab's Avatar
If he cannot do the size you need I could. I'm in Freeland. Nice looking hood hoop too.
Page generated in 0.18041 seconds with 35 queries
