How to easily make a homemade smoke machine? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 14th, 2011, 09:30 PM   #1
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
Default How to easily make a homemade smoke machine?
Has anyone ever made a homemade smoke machine before to test out evap leaks in their emission system? If so, what did you use to make it and how easy was it? Thanks :)
Catnip 0_o is offline   Reply With Quote
Old December 14th, 2011, 09:49 PM   #2
MilwaukeeF350
Dan
subscribe this thread
Those machines are rip off. $1000-3,000 while I am sure somebody could build under $100.
Old December 14th, 2011, 09:54 PM   #3
GREASYHANDS
GREASYHANDS's Avatar
Go buy a party fog machine. The principal is the same.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old December 14th, 2011, 09:58 PM   #4
buttercr125
I work out
buttercr125's Avatar
You are supposed to use pure nitrogen when pressurizing the EVAP system though. Using regular air could be dangerous. Just an FYI.
Old December 14th, 2011, 10:01 PM   #5
GREASYHANDS
Unless baby oil turns into pure nitrogen when heated I dont think many of the tool manufactures are doing it right. And how the fukc are you supposed to see a nitrogen leak?
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old December 14th, 2011, 10:12 PM   #6
buttercr125
I work out
You hook the nitrogen tank to the smoke machine to pressurize the system and look for the smoke. You are not supposed to introduce oxygenated air into the EVAP system. Most if not all EVAP smoke machines are either pressurized with nitrogen or have a way to hook a nitrogen tank to them.
Old December 14th, 2011, 10:22 PM   #7
GREASYHANDS
So every time I open my gas cap to fill my tank and oxygen enters my tank that's bad?
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old December 15th, 2011, 12:18 AM   #8
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
GREASYHANDS...I like turtles too :)
Old December 15th, 2011, 06:50 AM   #9
Cool parts peddler
Ironman Offroad's Avatar
WE have been using a Smoke Pro for over 5 years and no issues w/regulated shop air. My opinion is nitrogen is an ultra safe option. A Smoke Pro is only a couple hundred bucks.
Old December 22nd, 2011, 09:00 PM   #10
MichiganJeeper
invite me to your house
MichiganJeeper is offline   Reply With Quote
Old December 23rd, 2011, 05:46 AM   #11
JeepInABox
In too deep
JeepInABox's Avatar
Mopar leak detector uses shop air.
I check all connections, look for damage to the charcoal canister or lines, check the purge solenoid, blow the system out with air and change the gas cap.
You can find most issues this way.
Old March 16th, 2012, 09:59 AM   #12
John D
John D's Avatar
The OPs question wasn't answered, so who does this test on the north side of Grand Rapids? I need to get some things checked out.
John
Old March 16th, 2012, 11:30 AM   #13
GREASYHANDS
I did learn why. Not from experience tho. As the oxygen mixes with the fuel vapors the mixture becomes more volital than just fuel vapor alone. The possibility of a spark or arc in the tank at the fuel pump could cause it to ignite. That is why its recommended to use an inert gas to pressurize the system.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old March 17th, 2012, 07:50 PM   #14
John D
John D's Avatar
I borrowed a smoke machine from a friend to test my intake for leaks. It had all the attachments included in the kit for checking everything and the only provision for hooking up pressure was from shop air. So, I dont know what to say except shop air seems to shop just fine.
Page generated in 0.22307 seconds with 65 queries
