will not run when cold - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 14th, 2011, 04:56 PM   #1
spr_chicken
spr_chicken's Avatar
Send a message via MSN to spr_chicken Send a message via Yahoo to spr_chicken
Default will not run when cold
We have a 1989 chevy 1/2 ton 4x4 that is stalling when it is cold. When you start it up it will fire up then stalls in about 10-20 seconds. I checked the codes and it came up throttle positioning sensor, knock sensor (it was broke off at the plug), and coolant temp sensor. We replaced them and it is still stalling. If you spay starting fluid or carb cleaner into the throttle body it will stay running. It starts fine as long as it is warm. I did notice that you have to spay towards the passenger side injector to keep it running. If you only spray the drivers side injector it will still stall.
So does anyone have a clue on what is going on and how to fix it?
spr_chicken is offline   Reply With Quote
Old December 14th, 2011, 07:06 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
sounds like you need to check fuel pressure. that would be a good place to start if nothings been mucked with. has the fuel filter ever been changed? if not that could be part of the problem to.
Yetti
Old December 14th, 2011, 07:14 PM   #3
jimhri
jimhri's Avatar
i no longer run, regardless of the temperature
jimhri is offline   Reply With Quote
Old December 14th, 2011, 09:10 PM   #4
GREASYHANDS
GREASYHANDS's Avatar
Sounds like a bad fuel injector or low fuel pressure. Check to see if there is fuel spraying from the passenger side injector. A timing light pointed at the injectors will help you see the fuel spray.
Also unplug the coolant temp sensor, this will richen the fuel mix and may let it run longer.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old December 14th, 2011, 09:26 PM   #5
frdboy
frdboy's Avatar
That's what I was thinking, I have seen those injectors not work cold and then start after a few mins.
Old December 16th, 2011, 12:37 AM   #6
spr_chicken
I was like that until I lost 130 lbs. Now I don't mind running...
We tried unplugging the coolant temp sensor and it did not help. I will try the timing light trick. I wanted to check the timing anyways. Thanks for the idea...
The funny thing is I at first thought it might be an injector or fuel problem. But my father in-law and his friend who owns the truck wanted me to try changing the other stuff first. The owner originally took it to a shop in Grand Haven and the said it was the oxygen sensor. He had them change it but that did not help either.
Old December 16th, 2011, 10:45 AM   #7
bdd1469
bdd
bdd1469's Avatar
The first thing to check is fuel pressure.You can loan the tool from autozone for a $150 deposite.After you detrermin that you have 10-11 psi check your idle air control valve,and check your egr valve for a chunk of carbon holding it open.If the truck is running,and you unplug the coolent temp sender,the idle should change.there may be two temp senders,one for the dash,one for the computor,make sure you check the correct one.
Im betting on a bad fuel pump.
Old December 18th, 2011, 01:30 PM   #8
pigfat
GONE COMMANDO
pigfat's Avatar
it could be the coolant temp sensor connector. they go bad and still wont read. It is probably reading -36 degrees.
pigfat is offline   Reply With Quote
Page generated in 0.35082 seconds with 47 queries
