need a rough idea on cost of steel - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 29th, 2006, 01:16 AM   #1
Blackjackbender
Default need a rough idea on cost of steel
how much would 20' of 2x2 1/4" wall cost roughly? id stop by my local steel shop but am currently 200 miles away from them.
also a rough idea on 10' of 3" wide flat stock 1/4" thick cost?
any rough idea helps.
thanks
Ty
Old September 29th, 2006, 01:18 AM   #2
Mclovin
"The Situation"
Mclovin's Avatar
Alexander Gram bell may be able to help.
Old September 29th, 2006, 01:47 AM   #3
Blackjackbender
its fucking 1:45 im trying to figure out a cost of a project i thought of at 1:00 o'clock.
Old September 29th, 2006, 01:50 AM   #4
IrishChef
Comfortably Numb
IrishChef's Avatar
As would Webster.
"Trade me right the fuck now!"
IrishChef is offline   Reply With Quote
Old September 29th, 2006, 08:59 AM   #5
About 50 cents a pound..
Flat bar is cheap, the tube products are a touch more expensive.
Depends a LOT on where you go. I see people paying 100-200% more than what I pay at Pontiac Steel.
Also depends on whether there's a drop that size or if they are cutting it for you(and the type of cut they use).
AND depends on the grade of steel. For example, 2 x 2 x 0.25 receiver stock is about $20 a foot, where 2 x 2 x 0.25 A500 is maybe $3-$5 a foot...
Lets see..
10' x 3" x 0.250" cold rolled = 25.5 lbs, so probably about $15 or so
20' x 2" x 2" x 0.250" wall HREW = 119 lbs, probably about $60-$80 or so for a stick.
What are you doing with that much thick tube? Hopefully not going on a vehicle...
Old September 29th, 2006, 01:50 PM   #6
Blackjackbender
Lets see..
someday. weather its in a kit for or I make it.
I was bored one night and started pricing out how much it would cost to build a long arm kit versus buying one. I probably wont build one but what else do you have to do at 2 in the moring.
Thanks for the help Jesus .
right not my estimate is 900 or so. comes to 800 with out getting some square tubing inserts made plus an easy 100 for consumables, cut off discs, drill bits, and bolts. the extra 600 for the clayton kit is making alot more sense now.
Page generated in 0.18960 seconds with 41 queries
