best paint for off road? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 13th, 2011, 04:45 PM   #21
cannaert
No more Jeep
cannaert's Avatar
Originally Posted by DuffMan View Post
POR 15 = isocyantes.
Isocyantes = B A D .
Also, POR 15 needs humidity to dry - it won't dry in a good, ventilated, climate-controlled paint booth...
All paints are bad for you to breath in, even the new Waterborn stuff. But anything that needs or uses a hardner will mess you up over time.
Old December 13th, 2011, 04:45 PM   #22
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Originally Posted by Windsorf350 View Post
thought about that. also thought about por15 but how would that hold up on a rim?
POR 15 works great but it has to be coated with either paint or clear coat. it's UV sensitive, it'll break down pretty quick if it's not sealed. And it's quite expensive
Just go with farm implement paint, reasonably priced and it'll last a lot longer than rattle can/por 15. I mean if you think about it, it's made to be on something that's going to be in mud/shit/crud all day everyday
wave_crusher is online now   Reply With Quote
Old December 13th, 2011, 04:49 PM   #23
cannaert
No more Jeep
cannaert's Avatar
You dont need to prime unless you took it to bear metal.
But if you want a good base to prime it with look at an epoxy primer. Costs is high but that stuff is wonderful.
Old December 13th, 2011, 04:54 PM   #24
Windsorf350
Rusty Racing
Windsorf350's Avatar
im sand blasting them but i think ill hit them with some epoxy primer then tsc black paint. price shouldnt be too bad on primer we get a preatty good deal through finish masters at the school.
thanks for all the input guys... really apretiate it ill post some pics of finished product. still need to weld in the rock rings before paint
Windsorf350 is offline   Reply With Quote
Old December 13th, 2011, 04:57 PM   #25
7.3X
Fullsize support vehicle
7.3X's Avatar
Mil-Spec CARC.
7.3X is offline   Reply With Quote
Old December 13th, 2011, 05:02 PM   #26
skife
skife's Avatar
x3 on implement paint, next jeep is getting painted with it.
Old December 13th, 2011, 05:03 PM   #27
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Originally Posted by curbdog17 View Post
Rattle can black. easy touch up and cheap.
yups and walmart stuff at that ! 98cents a can!!!!!
H.o.r.e
Old December 13th, 2011, 05:06 PM   #28
Windsorf350
Rusty Racing
think that would turn out half way decent? might do that... does that stuff need to be thinned or anything just got some seems preatty thick... or just shoot it out of a primer gun
Old December 13th, 2011, 05:18 PM   #29
schanxj
schanxj's Avatar
i gots lots of them but then i gotta clear it cuz its water based
Not to mention the fact that it is considered a weapon and will get you expelled.
schanxj is offline   Reply With Quote
Old December 13th, 2011, 05:20 PM   #30
Windsorf350
Rusty Racing
im not going to bring a paintball gun to school im not retarted... and if i was going to do a crappy paint job like that why would i bother bringing it to schoolt to use a booth?
Old December 13th, 2011, 05:30 PM   #31
GearDrive
A little slow
GearDrive's Avatar
TSC implement paint is oil based and takes a long time to dry. Buy the hardener for it, it will speed up the drying time and thin it a little. Goes on thick but flows out well.
GearDrive is offline   Reply With Quote
Old December 13th, 2011, 05:40 PM   #32
Windsorf350
Rusty Racing
okay thanks is the hardener actually for the tsc implement paint? so i just get it the same spot i got the paint or can i use regular hardener for solvent based paints?
Old December 13th, 2011, 05:59 PM   #33
Trendsetter
Trendsetter's Avatar
Send a message via AIM to Trendsetter Send a message via Yahoo to Trendsetter
go to finish master and get some slicksand for the primer it is a poly based primer, stupid simple to spray, very tough and a gallon of it is CHEAP. once you sand that down, get some imron or if you want save some coin get some centari or what ever it is and then clear it with imron 500S If you use the 500S clear it is a very tough durable finish and easy to touch up. Buy doing this it allows you to skimp a little on the base coat since the strength is in the clear. I use it all the time at work in the marine industry if it will stand up to salt water, and insane high temps of dark huls on the water getting splashed with cold water with out issue then I think your more then good on the jeep
Trendsetter is offline   Reply With Quote
Old December 13th, 2011, 06:29 PM   #34
skife
skife's Avatar
My uncles used to paint dumpsters with implement paint when they had their dumpster business.
Old December 13th, 2011, 06:57 PM   #35
Blue XJ
The Green Machine
Blue XJ's Avatar
Send a message via AIM to Blue XJ
I sprayed mine with implement paint. It has thinning instructions on the can, I had to thin it a little more than it said to get it to flow out of the gun nice. I used a little extra hardener as well to try and make the surface tougher.
I will say that after the first time wheeling with it, it was just as scratched as normal paint.
Blue XJ is offline   Reply With Quote
Old December 13th, 2011, 07:06 PM   #36
Windsorf350
Rusty Racing
for the body im just looking for cheap spray over old paint type deal. ill see how it holds up on the wheels i want to find a new cab before i paint the truck and i need to get some bed sides to hang on the cage yet.
Old December 13th, 2011, 07:15 PM   #37
booblinker
Sore and Tired 24/7
booblinker's Avatar
Chassis Saver, pretty much the same stuff as Por 15, but a lot cheaper.
Old December 13th, 2011, 07:56 PM   #38
jeepjumper
Does not own a jeep...
jeepjumper's Avatar
i took a gallon can of Rustoleum mixed it with paint thiner till it was thin enough for a paint gun and sprayed my old truck. Then after about 7 or 8 coats of clear coat it looked good it was fairly durable, and it was very easy to touch up.
jeepjumper is offline   Reply With Quote
Old December 13th, 2011, 08:00 PM   #39
curbdog17
Mini Van
curbdog17's Avatar
That seems like alot of clear, but im not a painter.
Old December 13th, 2011, 10:17 PM   #40
jeepjumper
jeepjumper's Avatar
it was a lot haha but i dont like painting and i wanted it to have a good protection against dirt and scratches, it was a full time trail rig. normally all you need is 2 or 3 coats, buff it out and it will shine
Page generated in 0.68081 seconds with 83 queries
