| Home | Register | iTrader | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Store | Photo Gallery | Chat |
Thread Tools |
#1 |
Door Alignment Specialist
Almost Alloy Kit Review
I purchased the Almost Alloy Kit from Iron Rock Off Road.
I am putting them in a 98 Jeep Cherokee XJ with a 79 Ford Dana 44 axle with 5.38 gears, lunch box locker and 36" tires, powered by a stock 4.0 motor. http://www.ironrockoffroad.com/Merch..._Code=IR-S_AAK The kit came with 8 of these plates ![]() I also purchased new Spicer 5-760 U-Joints. ![]() Full Circle clips from Napa. ![]() I had a set of stock Dana 44 shafts machined to accept the full circle clips. ![]() The U-Joints installed like normal, remember to put the clips over the u-joints before installing them onto the shafts. ![]() I put a little extra grease into the caps because I was going to be welding near them and did not want to burn too much grease out. ![]() First I tacked the plates on and made sure they would fit inside the steering knuckles OK. ![]() They were tight but did seem to just fit. I welded the Almost Alloy Kit on in steps, just a small bead at a time. With a few minutes between each weld to give them time to cool. After installing the shafts back in the axle the welds were hitting the lower ball joint nut. I had to grind the weld smooth. ![]() Now I have just enough room to spin the shaft in the axle housing. The passenger side had a different type of ball joint in it and it required some grinding so it would not make contact with the plates. ![]() ![]() I will report back when and how the system fails. UPDATE So yesterday (Sept. 1 2012) my front axle shaft broke. I was bound up in some rocks and the drivers side stub shaft broke. The U joint still feels very good and the "Almost Alloy" plates have seemed to hold up fine. ![]()
#4 | |
I have never seen a review on this product before and was and still am a little leery about how it will perform. Time will tell. I will post when and how and what fails in the front axle when something happens. But I will not be wheeling again until late winter/early spring 2012. |
#5 |
It was not difficult to do, the worst part is waiting for things to cool during the welding process. If I break a lockout instead of a U-joint or the ears off the shaft it will have been worth it to me.
We will see what happens. |
#6 |
┌∩┐(ò_ó)┌∩┐
Im interested to see how these work out for ya. I was interested in these a few months ago but everyone here steered me away from them. But I wasn't sure why, they strengthen the weak ears of the d44 and cost way less than chromos.
As for failure my money is on either a lockout or a ujoint |
#8 | |
#9 |
Stacks n Boggers
I never broke the ears on my 44 shafts... I broke the inner at the yoke once and at the carrier once. Never the ears, I think the ears break when your turning too hard and on the throttle, mine broke with the wheels straight and the hammer down
![]() 97 Dakota truggy on tons and 43's 07 CTD tow pig MinniMax Tuner 5" turbo back and Egr delete |
#10 |
![]() ![]() I should be taking the jeep out within the next few weeks. I will report back after that.
Bare Bones Offroad
#12 |
I work out
X2....I just swapped a 60 in mine but curious as to how well these work. I have broken countless Dana 44 shafts and U-joints.
If your thinking about dealing with JoshuaCripe read the link below first!! http://www.greatlakes4x4.com/showthread.php?t=219276 |
#14 |
#15 |
Still telln it like it is
I totally get that and obviously this fixes that problem. But what do you do when you need to replace the joint? Or do you just say fukc it and get a new shaft set. Or do you just get nutty with your grinder?
#16 | |
Time will tell on this one.
Bare Bones Offroad
#17 |
I fixed it!!!
I installed a set of these on my dana 30 hp in my xj last summer. I have 33mtrs and a lunch box locker. I have not broke a shaft since. I just installed 4:88s so I will see how they hold up now. I did not burn mine in as heavy so when the u joints do freeze up I can grind them off.
#19 |
The "Fawk Yeah Buggy"
Through expierence I havefound that with stock shafts and full circle clips will stretch the ears/wobble the holes. When I tried this on both my d35 and d44 shafts, after X amount of time the caps no longer fit snug in the holes. By allowing the caps to turn in the softer metal of the stock shafts damages them. I have tack welded my caps since and have had no issues.
#20 | |
I am hoping that this keeps it from happening again. I have an odd ball dana 44 and have trouble finding shafts. I need these to hold up a bit longer.
Bare Bones Offroad
| Thread Tools | |
