Sway bar???? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 28th, 2006, 10:05 PM   #1
SANDMAN
Shhhhhh
SANDMAN's Avatar
Default Sway bar????
Ok so real quick heres what I did..I put solid toyota axles under my nissan d-21 and I want to run a sway bar I started pricing them and they run from 200 to 450 bucks. Does anyone know a way to do it cheaper???? Is it possible to hit a junk yard and use a stock toyota sway bar????
Thanks for any help
SANDMAN is offline   Reply With Quote
Old September 28th, 2006, 10:46 PM   #2
Sure.
You need to find a sway bar thats about the right dimension, since you are running the toyota axle, a stock toyota one ought to be about right.
Grab the links that go to the axle, and use those, too. They may need to be lengthened or shortened, depending on your lift.
Heck, if worst comes to worst, lemme know, I've got a whole 85 yota in the back yard with a rotten frame. Front bar should still be there.
I'm just south, in the Big L-O...
Old September 29th, 2006, 12:08 PM   #3
SANDMAN
Shhhhhh
SANDMAN's Avatar
I sent you a pm thanks Jesus
Page generated in 0.18821 seconds with 32 queries
