tube benders - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 9th, 2011, 10:28 PM   #1
jessezipper
Default tube benders
Im thinking about getting a tube bender for myself to make a cage and whatnot in my garage... what are you guys using in your garage???
jessezipper is offline   Reply With Quote
Old December 10th, 2011, 07:03 AM   #2
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
I have a jd2 ratcheting bender. I am converting it to air over hydraulic though. Make nice bends and works very well.
Old December 10th, 2011, 07:23 AM   #3
jaysusr
jaysusr's Avatar
Jd2 also. Like it. Dies are not cheap! Other brands have less expensive dies, not sure how good they bend though.
Old December 10th, 2011, 07:51 AM   #4
welderbrian
welderbrian's Avatar
I have the probender pro3 it uses the 105 dies cheap and works good
welderbrian is offline   Reply With Quote
Old December 10th, 2011, 08:26 AM   #5
dougstephvoor
Supreme Chancelor!
dougstephvoor's Avatar
Default professional?
But is it a pro quality?
dougstephvoor is offline   Reply With Quote
Old December 10th, 2011, 08:41 AM   #6
Tab
Tab's Avatar
ProTools 105hd converted to hydro on a rolling stand. When you get the dies spring for the 240 degree ones. Its a bit extra but WELL worth it.
Old December 10th, 2011, 08:55 AM   #7
buttercr125
I work out
buttercr125's Avatar
JD2 model 32 with a harbor freight air over hydraulic ram and a swag offroad adapter kit. Works great!!
Old December 10th, 2011, 09:00 AM   #8
bigbchevy
missmrgreenagain
bigbchevy's Avatar
jd2 mod 4 full power on rollers !
H.o.r.e
Old December 10th, 2011, 10:56 AM   #9
Eric99tj
Just bump it....
Eric99tj's Avatar
I have a ProTools 105hd converted to air/hydro on a rolling stand setup. I love mine. I used the Copperhead Fab conversion brackets to convert it to air/hydro.
Southern Michigan Rockcrawlers
Eric99tj is offline   Reply With Quote
Old December 10th, 2011, 11:00 AM   #10
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Worth stating again.
Old December 10th, 2011, 11:12 AM   #11
frdtrckmnrich
FORD The Best Never Rest
frdtrckmnrich's Avatar
Same here....
Old December 10th, 2011, 11:25 AM   #12
buttercr125
I work out
x3 Here. I got the 90* dies but I got a smoking deal on my bender with the die. Someone purchased it, never used it and had it listed for sale on pirate. For the price I got it for I couldn't pass it up. I go it for less than the bender by itself.
Old December 10th, 2011, 09:51 PM   #13
jessezipper
i was looking at the jd2, manual version..how much of a pain in the ass is it to bend manually?? i can easily hook up a hydrolic assist from harbor freight later..
Old December 10th, 2011, 10:02 PM   #14
buttercr125
I work out
Manual bending is not fun. If you go that route make sure you have a good stand and its mounted solidly.
Old December 11th, 2011, 01:48 PM   #15
cerial
Direct Drive FTW
cerial's Avatar
I went with a pro32 and a 240 1.75 die. Everything to my door was less then $1300. It is a little more then a "upgraded" ratchet style bender. But, air/hydro is the way to go.
Old December 12th, 2011, 08:58 AM   #16
jthomp
jthomp's Avatar
JD2 ratchett bender. Not fun but not unreasonable, unless you're gonna do a lot of bending.
jthomp is offline   Reply With Quote
Old December 12th, 2011, 09:13 AM   #17
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
I have the JD2 model 32 manual...I do not have a problem bending manual and I have done three cages and one buggy
Old December 12th, 2011, 09:36 AM   #18
trailrail302
Im going FAST!!!
trailrail302's Avatar
What buggy did you ever build?
(I dont recall any 60's being in your shop. or v8 for that matter)
Dont forget about the Aluminum Tower we did for the boat...
I will add the manual is not that bad Its a pain at times but I actually like it for some things. doing it by hand you can get a good feel and keep it precise. Not to mention you can bend pretty quick with the manual ratchet set up.
I would say one of the biggest down falls to manual bending is that your bender is not mobile. its bolted to the ground in a specific location in the shop, so if you have multiple things in the shop or need to roll it to a different location your stuck.
trailrail302 is offline   Reply With Quote
Old December 12th, 2011, 09:54 AM   #19
liv2mx
i like jungle gym's.
liv2mx's Avatar
i did all of my rig with a manual ratchet bender.cory built his whole buggy with a manual bender.
with that said i am ordering the hydraulic upright one.
this is on sale for 499.00 the pro 3 www.probender.com
Old December 13th, 2011, 09:21 AM   #20
Christmas Cookie
oh yea...I fogot about the boat tower thingy...which is awesome by the way...and you helped to build the buggy ash hole
Page generated in 0.35753 seconds with 83 queries
