Overland Trekking - 2002 WJ Build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 7th, 2011, 02:30 PM   #1
fishyoo7
fishyoo7's Avatar
Default Overland Trekking - 2002 WJ Build
Well, I started with a 2002 WJ Overland, 80,000 miles. Vehicle is from NV, so no rust. But it was not maintained well - bunch of leaks.
So, I had this for 3 days and had a blowout, and the spare is shot.
Got it home, and the wife said that I should order the lift and tires that I wanted and just do it, instead of getting a few junk tires to buy time!
Picked up a Zone 4" lift, with Nitro Shocks. Also, got a steering stabilizer and JKS disconnects. Put on some 2012 JK Rubicon take off wheels and tires.
I got it together last night to make it to work today. Still need to put in the transfercase drop, steering stabilizer.
Overall, the lift gave me 3.5" in the front and 2.5" in the rear. Rockers moved up 5" with the lift and tires.
Name:	2002 WJ Stock.jpg
ID:	86643   Click image for larger version
Name:	2002 WJ 4in Lift with JKs.jpg
fishyoo7 is offline   Reply With Quote
Old December 7th, 2011, 03:06 PM   #2
branch92
Only in a jeep
branch92's Avatar
what motor?
branch92 is offline   Reply With Quote
Old December 7th, 2011, 03:10 PM   #3
fishyoo7
fishyoo7's Avatar
4.7L High Output.
It still gets up and goes well with the 3.73 axles and the V8. Better than my JK was.
Old December 7th, 2011, 03:15 PM   #4
firecat
firecat's Avatar
I like that
firecat is offline   Reply With Quote
Old December 11th, 2011, 08:39 PM   #5
fishyoo7
fishyoo7's Avatar
Installed the Zone Steering Stabilizer this weekend. That went on easy.
Also changed out the Power Steering Hose that goes from the pump to the Fan Motor. It was leaking at the pump. So Far So Good and no leaks. The trick for me was to install the bottom fitting first, then the top fitting. Then zip tied the line to keep it from moving around.
Old December 11th, 2011, 08:42 PM   #6
fishyoo7
fishyoo7's Avatar
Also went and got it washed. It cleans up pretty nice.
Selling my take off 17" rims -
5 - 17" Wheels off a WJ (5 on 5), also fits JK, WK, XK - Great Lakes 4x4. The largest offroad forum in the Midwest
Name:	WJ Cleaned Up.jpg
Old December 11th, 2011, 08:50 PM   #7
Scibbyz99WJ
veni vidi vici
Scibbyz99WJ's Avatar
Send a message via AIM to Scibbyz99WJ Send a message via MSN to Scibbyz99WJ Send a message via Yahoo to Scibbyz99WJ
nice Jeep! I love the 02 Overlands. that 3" tip is awesome
have you checked out the transfer case and 4WD? you said it wasnt maintained well, and the 247 t-case as well as the varilock axles take special fluid. the transfer case fluid being mopar specific, and the axles requiring a friction modifier.
do not put on the t-case drop. for whatever reason it worsens driveline vibes and accelerates driveshaft wear. just ask JeepForum
Scibbyz99WJ is offline   Reply With Quote
Old December 14th, 2011, 01:11 PM   #8
fishyoo7
fishyoo7's Avatar
I probably should plan on servicing the T-case too.
I need to change the diff fluids - I bought the fluid and friction modifier, just need to get pinion seals and axle seals.
The t-case drop actually helped my vibrations. I drove it first without and it was bad, put it on, and it got better.
Old January 19th, 2012, 01:37 PM   #9
fishyoo7
fishyoo7's Avatar
Just as an update, the Jeep settled about .25" in the front and .5" in the rear. So I am at about 3.25" front and 2" in the rear. Sits level front to rear. Has 17" clearance at the rockers.
I ordered a front receiver mount and portible winch mount. Should have those next week.
Old February 14th, 2012, 07:36 AM   #10
fishyoo7
fishyoo7's Avatar
Here is an update. Mounted a Warn front receiver. It was pretty straight forward. Unfortunately, the pin hole lines up with the front facia. So I just cut the facia at the top, so when I need to put the pin in, I just push the plastic inboard and it still looks good.
ID:	89196   Click image for larger version
ID:	89197   Click image for larger version
ID:	89198   Click image for larger version
Old February 15th, 2012, 12:45 PM   #11
fishyoo7
fishyoo7's Avatar
Front View
Old April 5th, 2013, 03:22 PM   #12
fishyoo7
fishyoo7's Avatar
Installed a set of the Alloy Axle Ball Joints 11800 for the JK / WJ. Went it fine. Seem to work well.
Bought them at EAD Off-road.
http://www.eadoffroad.com/jeep/wrang...ball-joint-kit
ID:	104060   Click image for larger version
Old April 5th, 2013, 03:25 PM   #13
fishyoo7
fishyoo7's Avatar
Installed a used set of Spydertrax 1.25" WJ wheel spacers. No more rubbing when I turn now.
ID:	104062   Click image for larger version
ID:	104063   Click image for larger version
Old April 5th, 2013, 03:45 PM   #14
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Looks great, i've always wanted to build a WJ for trails; almost did to the GFs 01'
Looking forward to more
Old April 5th, 2013, 03:51 PM   #15
fishyoo7
fishyoo7's Avatar
Also had to replace the Zone steering Stabilizer, it developed a leak and was out of warranty. Picked up a Moog one from Rock Auto.
Old April 5th, 2013, 04:50 PM   #16
joe_jeep
welfare wheeler
joe_jeep's Avatar
nice! i just pick the wife up an 03 wj with the h0 v8. love that motor!
wish it was in my rubicon lj!
Old April 5th, 2013, 06:26 PM   #17
ATVLIFESTYLE
ATVLIFESTYLE's Avatar
Nice man. I have an 04 WJ that is going to be getting a simliar makeover soon.
ATVLIFESTYLE is offline   Reply With Quote
Page generated in 0.32228 seconds with 76 queries
