Ford 8.8, 4.88, E-locker, 31 spline $1200 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 28th, 2006, 03:11 PM   #1
JKOZ
yes
JKOZ's Avatar
Default Ford 8.8, 4.88, E-locker, 31 spline $1200
Ford 8.8 that we built for my ZJ and only ran for a month or two. Only a couple hundred miles on it.
Freshly built 8.8 with a solid spacer, precision gear 4.88 gears, all new bearings, seals, brakes, Detroit E-Locker, flange adapter.
The E-locker runs a normal diff cover, there is only two wires that come out through a small hole in the housing. The units are an open diff when they are not engaged, then a spool when they are engaged.
The only thing it doesn't have is the emergency brake hardware or shoes, you can add it if you want. I didn't run e-brake at all.
It has coils spring brackets welded on the axle for TJ / ZJ. Only the coils spring brackets not any of the control arm brackets.
This would work great in YJ XJ ZJ .......................
JKOZ is offline   Reply With Quote
Old October 22nd, 2006, 10:28 PM   #2
JKOZ
yes
JKOZ's Avatar
Btt
Page generated in 0.16246 seconds with 29 queries
