Standard trans interchange - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 6th, 2011, 05:14 PM   #1
dumperdave
dumperdave's Avatar
Default Standard trans interchange
Working on a 95 sonoma with a 4.3 and standard trans. Interchange says only 95 will work. I found a 92 and wonder what the difference would be. If anyone knows I would appreciate your input. Thanks.
dumperdave is offline   Reply With Quote
Old December 6th, 2011, 08:52 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
2 or 4wd? 92 will work so long as it came from a s-10. Prior to 1993 they were called HM-290 and 5LM60. these early transmissions had 4 shift rails. in 1993 they were renamed NV3500 and changed internals significantly one of these changes being a single shift rail. they also changed the input bearing from a ball bearing to a roller bearing. physically any transmission up to 1995 will work. in 1996 they went to an internal slave cylinder.
Old December 7th, 2011, 04:20 PM   #3
dumperdave
dumperdave's Avatar
Its 2wd and the slave goes into front of bell housing.
Old December 7th, 2011, 09:26 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
yea so anything 1995 or older will work.
Page generated in 0.12751 seconds with 35 queries
