1994 Wrangler SOA 4.6 stroker - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 6th, 2011, 11:52 AM   #1
MidnightWrangler
MidnightWrangler's Avatar
Default 1994 Wrangler SOA 4.6 stroker
For Sale is a 1994 Jeep Wrangler with a Cj7 front clip conversion, looks like a real jeep again with round headlights. It has tons of Aftermarket and custom parts. asking $6000 obo. Just lost interest in project will consider partial trade offers, still want some cash with it. Interested in Snowmobiles, and 4 wheelers specifically but may be interested in other stuff. the worst i can say is no. just looking to get out of the jeep world. just lost interest in it and all my buddies are leaving the off road scene. also just got laid off and bills are racking up in a hurry.
Engine: 4.6 Stroker professionally built by rick from Chucks engine exchange in Westland, He did all machining work and the full engine assembly.
bored .30 over with moly rings
Ford motorsports 24lb/hr injectors
Comp Cam for fuel injected engines
ReManufactured Head
99+ intake manifold w/ cold air intake and 99+ p steering setup
All ARP bolts other than head bolt.
Entire Rotating assembly fully balanced
Stainless steel header with flex pipes to prevent cracking.
Aluminum Radiator W/ electric fan w/switch
Flow master super 40 muffler, sounds great, best sounding jeep ive heard.
Everything on engine was sanded and painted before assembly, every bolt and bracket.
New water pump and power steering pump as well
everything on the engine is new other than the block and valve cover and main caps
Engine only has 1000 miles on it.
Drivetrain:
Recently Rebuilt ax15 5 speed manual trans and new clutch with resurfaced flywheel
Rebuilt np231j transfer case with sye kit
Ford 8.8 rear axle with 4:10 gears and ladder bar, open diff in right now but have a limited slip carrier that goes with jeep
Dana 30 front axle with brand new yukon 4:10 gears and bearings
Spicer u joints
SOA ( Spring over axle ) lift, flexes really good.
33" dunlop radial rover tires, 90-95% tread left. easily has room for 35" tires and im sure could prolly clear 38'S
MB motoring alumnium wheels in really good shape.
Reinforced skid plate/crossmember
Misc:
Soft top
All new red Polyurethane body mounts.
Skyjacker shocks
Delta headlights
all 1/4in Custom front bumper with stinger bar and winch plate and shackle mounts made from 1in plate.
Custom rear bumper made from 3/16in with trailer hitch welded in.
Smitty built xrc8 winch
Carr rota bar light bar with 4 kc rally 800 full stainless steel off road lights. over $300 a pair
Custom tube fenders in front made from 1/8 in plate and 1/8in wall tube.
Custom tube flares in back made from 1/8in plate and 1/8 in wall tube
180amp high output alternator
Brand New optima yellow top battery
entire frame and underside of tub was wire wheeled and sanded, inside of tube was sanded with a scotch brite pad and have used over 2 gallons of chassis saver between the bottom side of the tub, the frame axles and steering and the inside of the tub, this baby is rust proofed.
Jeep is very very solid, spent a very very long time fixing any and ALL rust, floorboards frame and body are completely solid and almost completely free of rust. only surface rust in a few spots where paint is chipped. ONLY SURFACE RUST
Brand New carpet on the inside with quadratech molded floor liners.
comes with hard top and full hard doors
Power inverter mounted under dash
New Radio/cd player with aux jack and usb port and sound-bar
Jeep still needs a little TLC to make the project complete but overall is a very solid vehicle that could be loads of fun for years and years to come. Runs and drives and can be driven down the road but just little things that need to be buttoned up.
Needs rear shock mounts welded on frame and needs the adjustable map sensor i built soldered in and tuned. Needs rear shaft too.
Feel free to contact me with any questions. 2487193084 Brett call or text anytime if the ad is still up it is still for sale or email me at Foxrider99400@yahoo.com
Last edited by MidnightWrangler; December 6th, 2011 at 12:16 PM. Reason: adding photos
MidnightWrangler is offline   Reply With Quote
Old December 7th, 2011, 04:39 PM   #2
MidnightWrangler
Bump
Old December 8th, 2011, 03:24 PM   #3
MidnightWrangler
any offers???
Old December 11th, 2011, 04:31 PM   #4
MidnightWrangler
Price lowered to $5500!!
Old December 12th, 2011, 05:49 PM   #5
MidnightWrangler
heres some interior pics
Old December 14th, 2011, 08:58 AM   #6
MidnightWrangler
bumb, Any Offers?????????
Old December 19th, 2011, 09:34 AM   #7
MidnightWrangler
Bump
Old December 27th, 2011, 11:08 AM   #8
MidnightWrangler
Bump. Still open to trades... Any Offers
Old January 10th, 2012, 07:55 AM   #9
wadshrp
wadshrp's Avatar
ill give you 10 dollars
Originally Posted by clarkstoncracker the d-bag View Post
I'll trade you my trail rig for the front wheels off your joe dirtmobile.
Originally Posted by chadcooper55 View Post
Hi steveo, this is chadcooper55. I like long walks on the beach and I can take two dicks in my butt at the same time. Want to go out some time?
wadshrp is offline   Reply With Quote
Old January 24th, 2012, 09:37 AM   #10
MidnightWrangler
Bumb
Old January 24th, 2012, 12:01 PM   #11
rinking
rinking
To be honest, you might have better luck selling it if you put stock fenders/ flares back on it!
rinking is offline   Reply With Quote
Old January 25th, 2012, 07:53 PM   #12
knixon804
THE GENERAL
knixon804's Avatar
interested in a 02 s-10 zr2 ext cab with matching topper?
2011 F-350, DELETED, INDUSTRIAL INJECTION SINGLE TURBO.... TOW PIG
UNDER CONSTRUCTION: LJ, STROKED LS, ONE TONS, 42" MTRS
JKU UD60s, 40" TRAIL GRAPPLERS, MACHETE BEADLOCKS, AEV BLOWER
OFF ROAD ANONYMOUS- PROUD TO HAVE A PROBLEM (231) 383-5664
knixon804 is offline   Reply With Quote
Tags
diesel, tj, truck, xj, yj
Page generated in 0.37043 seconds with 59 queries
