HELP! - D50/60 Axle Advice Needed - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 5th, 2011, 09:08 AM   #1
spinsession
Default HELP! - D50/60 Axle Advice Needed
How I arrived at the current state is a long story, but the relevant information is as follows: I've got a 99 F350 with a Dana50 (same as D60 except in the internals from what I understand) solid front axle. I currently have the axle shafts and diff carrier removed. Can you guys with D50/60 experience please weigh in on whether or not it is safe to drive the truck in the current condition?
My question really pertains to the hub assembly. Will it blow apart if the stub shafts are not installed?
I have experience with D30s, and I know that the stub shaft/nut is an integral part of the overall hub assembly. On this D50 though, the hub has a large nuttish looking thing on the back side that appears to hold everything together. Additionally, when the stub shaft is properly installed the only thing holding it into the hub assembly is a circlip...which I know would not hold this beast together if things started falling apart. These two observations lead me to believe that the hub is self-sufficient and is not dependent on the stub shaft, but I'd really like additional opinions from those who experience with these larger axles.
HELP!
spinsession is offline   Reply With Quote
Old December 5th, 2011, 09:39 AM   #2
7.3X
Fullsize support vehicle
7.3X's Avatar
Drive it you are fine. The wheel bearings are unit bearings and not held together by the c-clip. or nut.
7.3X is offline   Reply With Quote
Old December 5th, 2011, 10:39 AM   #3
Bones
Bones's Avatar
correct
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old December 6th, 2011, 10:15 PM   #4
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
x3 all will be fine.
I'm the man in White.
Page generated in 0.21241 seconds with 35 queries
