Long dakota truggy build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 4th, 2011, 10:28 PM   #1
Bruster
Default Long dakota truggy build
Well went out and bought a dakota to start a truggy build.After trading josh back for the YJ ive been miserable without anything to wheel/work on.This build will take me sometime but im hoping to have it done within the year.
I first wanted to go rocks and a healthy ls,350 or 400,to a 203/205 doubler,42-44's linked front with coilovers or air shocks chevy 63"leafs in the rear.Now i have found a decent deal on craigslist on some chevy tons 60/14 bolt.
Now heres where i cant make my mind up.The frame has an area of rust on the driver side in front of the rear hanger,fixable but dont know if itll be worth the trouble to go through.My plan was to keep the stock frame then do some tube work from front to back but with this problem im starting to wonder if itll just be easier to chop it behind the cab and either go 2x4 square tube or start running round tub.If i start running tube itll be linked with air shocks then link the front with coil overs.I dont have a bender and i left my welder down in north carolina with the roomate.Instead of buying that 60/14 ive been thinking about taking that cash going to buy another welder and a jd2 bender so i can keep those purchase off the credit card haha.
Plan of right now is
350TBI/350,400 trans to either a doubler or ?
60/14 locked front welded rear
def going linked front with air shocks or coilovers..rear is up in the air
42's on recentered h1's
exo
full hydro
girlfriend wants it red with black cage.
thoughts..
Old December 4th, 2011, 10:44 PM   #2
Strangler
Strangler's Avatar
Keep it simple Eric. Buy a $100 HF mig, tack the entire build togeter and then ask to borrow a decent welder or a weekend in a garage with one. I'd chop the rear of the frame for sure, and since you need to change engine and radiator mounts for the chevy drivetrain, I would chop the front off too. Start fresh and keep it clean.
Old December 4th, 2011, 10:50 PM   #3
Bruster
Thats the plan strangler...keep it simple.I was hoping to be able to use the front frame section,but whats another 2 sticks of tube.I was considering going to buy the axles and use my buddys miller 210 for a bit then go buy my own.I just cant get over the deal i could get on those axles
Old December 4th, 2011, 11:00 PM   #4
Strangler
Strangler's Avatar
Tons are half price from two years ago. Not sure why, but its a good thing. Lots can be done without having them in the garage... if you have to pass on this set, another will be along soon. Full hydro? Chop the frame off.
Old December 4th, 2011, 11:17 PM   #5
Bruster
yeah seems like there everywhere on craigslist.Well ill finish ripping this pig down,taking most of it to scrap and going to buy tools and metal then start to piece it together
Old December 4th, 2011, 11:31 PM   #6
koochman450r
koochman450r's Avatar
Good start man. I would cut the frame in front of the cab. This is the same thing I'm doing except mine is a ranger. Good luck.
you won this battle.
Old December 4th, 2011, 11:39 PM   #7
Bruster
yup look at your thread a couple times a week!
Old December 4th, 2011, 11:45 PM   #8
koochman450r
I try not to. It just upsets me. I have a set of 63's if you need some. They just need bushings. Anyway good luck and happy building.
Old December 4th, 2011, 11:48 PM   #9
Bruster
yup i had ya in mind on the 63's.just need to figure out what way im gonna go with the build
Old December 5th, 2011, 09:14 AM   #10
disturbedsledneck
disturbedsledneck's Avatar
Cool build with some of good ideas.
I love the truggy's.
disturbedsledneck is offline   Reply With Quote
Old December 5th, 2011, 09:37 AM   #11
Bruster
What would everyone say the weight cut off is useing airshocks?Im gonna try to shed as much weight as i can.
Would really like coil overs but the spring rates have my mind in pieces haha.
Pros/cons of doing a 3 linked front,3link wishbone set up back?again just brain storming...
Old December 5th, 2011, 09:41 AM   #12
bigbchevy
missmrgreenagain
bigbchevy's Avatar
We can always burn it in at my place once u have it all set
H.o.r.e
Old December 5th, 2011, 10:53 AM   #13
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Dakota build
Old December 5th, 2011, 12:35 PM   #14
Bruster
well motor is ready to come out,Anyone want a 318 v8.Once the motor is out i will chop the rear section off,cut it up and haul it to scrap.
Beefy what size tube did you use for the exo and rear tube work?
Scott kick scooter out and ill bring this pile of rust over!
Reason for the back half
Old December 5th, 2011, 11:00 PM   #15
Mr. Beefy
BFT!
Mr. Beefy's Avatar
I used all 1.75 DOM for my cage and rear section. Build's looking good
What are you going to do for a motor?
Edit... 350
What do you want for that 318? I could always use a spare
Old December 5th, 2011, 11:16 PM   #16
Bruster
What's it worth to ya
Old December 6th, 2011, 11:42 AM   #17
Flat_Black
The Dodge Guy
Flat_Black's Avatar
if beefy dont want the motor, i might want the motor trans n tcase.
Old December 6th, 2011, 11:45 AM   #18
Mr. Beefy
BFT!
Mr. Beefy's Avatar
All you flat black I think I found something differend.
5.7L Hemi
Old December 14th, 2011, 08:26 AM   #19
Bruster
Well been thinking about ideas.
Rear is gonna get a 2x4 back half and leaf springs.Also trying to decide to keep the 318,get a new manifold and run propane through it.Trying to figure out my best trans/case options as well.
Old December 14th, 2011, 08:39 AM   #20
snow-turtle
Selective Hearing
snow-turtle's Avatar
you should look at some truggy pics , to get the brain thinking
snow-turtle is offline   Reply With Quote
Page generated in 0.80729 seconds with 83 queries
