My first Buggy build. - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 1st, 2012, 09:31 AM   #21
cerial
Direct Drive FTW
cerial's Avatar
Had a shed built so I could put all my junk in it and mate the engine and transmission together when I come back in December.
Spent the few days I had off doing family stuff mainly.
Links and other small things
Moved the engines transmissions and such into the shed
The brown lipe aux transmission
It's small but strong(and freaking heavy)
Preview of coming attractions: Once again small, strong, but this part is not so heavy despite lots of beef.
Old December 22nd, 2012, 10:31 PM   #22
cerial
Direct Drive FTW
cerial's Avatar
I was planning on using the orange 350 for 30k or so while I saved up for a crate engine that would give 400 lbs torque as low as I could get in the rpm range.
But, then I seen this and JUMPED on it.
It is a 68 472 (with 72k) putting out 500lbs just under 2300 rpm which is perfect for the ratios I plan on running. Due to the nickel content it's lighter then a 454 and if I install a aluminum intake it is only 50 pounds heavier then a sbc.
Here is the heavy intake
The engine also came with the 68 th400. I am going to see if my dad can use it on his Buick. If not I will just hang onto it and use it later.
Back at the house and checking measurements again to make sure everything will work. This dang thing is going to add 5" to my wheelbase but it should be totally worth it.
Pulled out the brownie and weighed it out of curiosity.
Double checking the layout. Everything still works out exactly as planned.
This is the measurement from the fan clutch to the flywheel.
First propeller shaft trans to brownie 7" shaft
Then another 7" shaft from the brownie to a box I had representing the transfer case
For a total length of 8' from the fan to the front of the transfer case.
I know this is long as heck but it is super long because I want to be able to work on the engine easily, replace the clutch easily, and if I decide to switch to a different transmission later (or swap out the brownie for a divorced klune box) I will have a lot of room to play with.
Began mocking up the shifter location. Everything will work out exactly as planned with plenty or room for skid plates under the motor and transmissions.
I will need to make a slightly longer main shifter to keep from hitting my elbow on the back of the cab. But the brownie shifter is perfect right here and easily within reach without being in the way of the steering wheel.
That is all I managed to do today. Doing family stuff tomorrow and should be able to start welding on the cab once again the 24th(weather permitting) and begin putting these measurements to good use.
I wanted to run the 472 before I left. But, it needs a oil pump which is special order no matter who I tried. The caddy to Chevy bell housing adapter is all special order as well as most of any performance parts. I need to run a relocated oil filter anyway so maybe I can find a pump that would make that easier.
I don't see any need to mess with this engine internally. Upgrade to hei and a lighter "stockish" intake and go is the plan. In stock form it will be reliable as all heck. The high compression will love the propane (without any mods). I will upgrade the water pump and other small parts to make it more reliable as they go out or when I simply get bored.
Old December 24th, 2012, 05:40 PM   #23
cerial
Direct Drive FTW
cerial's Avatar
Spent today cutting, notching, and grinding. Lots of prep work measuring the new motor, cage, back to the motor, check the cage, etc. Also had to move a few things around in the shed to notch in there as the shop was being used to paint a car.
Shed looks a lot better.
Lots and lots of tubing all prepped and ready to be welded tomorrow morning.
I have all the edges grinded down and the mating surfaces on the cage all grinded down it was just to dark to take a picture.
Everything is all good to go and set out I am just waiting for daylight
Old December 25th, 2012, 11:28 PM   #24
cerial
Direct Drive FTW
cerial's Avatar
Began welding this morning at 7am. It was a bit cold but not bad my mask kept fogging up though. I only had 3 hours to play with before I needed to do another family thing.
I welded up the back tubes, the six side tubes, and the front cross bar. I also fully welded up the bottom and cleaned it up.
It is hard to see in this camera phone picture but there is a 1/8 gap between the all the door pipes and upright. I plan on welding a gusset to the upright and tube to support it further once I get some plate steel.
The 1/8 gap is so the doors can slide inside the tubes without actually grinding against the rear upright.
Here is the doors they slide back to open and close. I only had the 3 pieces of balsa but you get the idea. There will be 5 total arms to the doors welded to one upright when finished to give side protection as well as stiffen the entire cage.
Here are the rear slip tubes. I only mocked them up because I did not have enough time to weld the 1.5" bracing from the bottom corners and bottom tube. The entire motor and bell housing sit under these tubes. This will make changing the clutch very easy. The rear watts link welds to them as well as rear suspension mounts. The axle tube sits directly behind these tubes. The crank pulley is only 4" away from the axle tube. The front has the same basic setup but is shorter.
I picked up all my junk and had a bit of extra time left over so I sat in the cab and checked the "mock up" seating setup.
Lots of leg room for the hanging pedals
Future grab handle location within easy reach
Good amount of clearance between the steering wheel and "door".
Good visibility to the left
Good visibility to the right
Over left shoulder
Over right shoulder
And over the dash
I was not 100% sure until I actually sat down but window bar is also the perfect height for comfy arm resting (once I side out the lexan that is).
That is as far as I could get this time. I will be ordering parts to mate the 465 to the 472 here over the next month through MTS(500cid.com). I hope to have the slip tubes front and rear welded up next time to get a bit closer to fitting this engine and transmission inside the cab.
Old December 26th, 2012, 07:35 AM   #25
hightech
Crawl 101
hightech's Avatar
Wow
hightech is offline   Reply With Quote
Old December 26th, 2012, 08:05 AM   #26
So you are fully welding everything as you go instead of tacking stuff up so you can change it if you decided to?
Old December 26th, 2012, 08:17 AM   #27
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Are you just winging this build? Do you have a drawing your going off?
Old December 26th, 2012, 08:24 AM   #28
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
at first I thought you were full of shit, but now I can see your vision. DOn't listen to these haters, I think it looks sweet, and everyone is jelous
Old December 26th, 2012, 08:25 AM   #29
Mulely
Mulely's Avatar
Send a message via AIM to Mulely
Looks like a forklift.
Mulely is offline   Reply With Quote
Old December 26th, 2012, 08:27 AM   #30
Bleay
sick of jackstand wheelin
Bleay's Avatar
Do you plan on standing up while driving?
Bleay is offline   Reply With Quote
Old December 26th, 2012, 08:27 AM   #31
cj65
cj65's Avatar
It does look good. And I didn't know you were capable of being nice. Maybe a new hch for the new year?
Old December 26th, 2012, 08:39 AM   #32
hamsmotorsports
hamsmotorsports's Avatar
What wheel base are you shooting for? Will the rear drive shaft be 7-8' long to get past all the drive train.
hamsmotorsports is offline   Reply With Quote
Old December 26th, 2012, 09:26 AM   #33
XJcoupe
1ton XJ
XJcoupe's Avatar
out of the box thinking, Mad Max movie build, you sure have set your standards high with the list you have compiled. I wish you best of luck and hope you pull it off with this torc monster of a motor.
you say its not a rockcrawler, then whats it going to be ?
rear engine BDMT or 4x4sandrail ?
will subscribe, because Im using the same motor running on propane in my rig
Old December 26th, 2012, 09:33 AM   #34
Bones
Bones's Avatar
I'm curious what the overall height will be once it is on a suspension/tires, etc...
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old December 26th, 2012, 09:54 AM   #35
Look out Grave Digger, there's a new Boss in town!!!!!!
Old December 26th, 2012, 10:15 AM   #36
Renegade II
Coil springs are for pens
Renegade II's Avatar
x2
Kind of looks like a tube version of a semi truck cab.
Originally Posted by cerial View Post
.................................Have Rebuilt 3.15 Tera-Low D-18 t/f case, twin stick, with OD Built by Herm
The reason I have been fighting so hard to get the cast bell housing is that I have a Dana 18 with a overdrive bolted behind the 465. It has a ps drop front and rear...............................
A SM 465 is precisely 973,712 x stronger than a Spicer 18 T-case and the helix angle on the low range kit splays the case apart real bad. Even with an inspection cover girdle that case (which was designed to NEVER have more than 265 HP run through it) will distort and blow apart. That and the fact that those overdrives blew apart regularly behind a stock 225 Dauntless should make for an interesting cup of gear soup behind a 472.
Old December 26th, 2012, 11:28 AM   #37
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Glad to see you get started on it! What "look" are you going for? If I were you I would quit welding and start tacking. You will change stuff as yoy go and it is a hell of a lot easier to cut tacks than welds!
Old December 26th, 2012, 11:44 AM   #38
Strangler
Strangler's Avatar
X2
Don't feel bad, fabrication is not for everyone.
Old December 26th, 2012, 02:49 PM   #39
chadcooper55
Originally Posted by Strangler View Post
X2
Way to asshole up my friendly post!
Old December 26th, 2012, 02:57 PM   #40
Strangler
Strangler's Avatar
Someone had to say it.
Tags
4x4, buggy, cerial
Page generated in 0.49089 seconds with 83 queries
