tire, rims, TMS - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 2nd, 2011, 06:47 PM   #1
FauxDuelly
Fix it, drive it, fix it
FauxDuelly's Avatar
Default tire, rims, TMS
Greetings All,
So I just bought a 2008 Dodge Ram Quadcab. Although the 20's with 33" street treads are nice looking and sporty......I would like something with a little more rubber and an aggressive tread pattern. Most of what I'm looking at either doesn't come in a 20" rim size and/or would be the wrong size tire.
My question is three fold. What is the minimum wheel size I can run? What is the stock back spacing on the 20" wheels? An if I switch rims what do I have to change on the Tire Monitoring System if I change rims, so that I don't have a light glaring at me?
Thanks,
Patrick
FauxDuelly is offline   Reply With Quote
Old December 3rd, 2011, 03:25 PM   #2
littletrucker
I'd hit that
littletrucker's Avatar
Im pretty sure you can switch to the ram 17s and clear your brakes.. I wouldn't run anything less than a 17. I also wouldnt run a rim with different offset that what the unit bearings are designed for ( So no rims with a shallow backspacing sticking way out)
And as for the tpms, you'll need to have a set of sensors installed in your new rims or the truck will not pick them up. and give you all kinds of warnings.
Old December 8th, 2011, 09:35 AM   #3
firecat
firecat's Avatar
Best solution? search "parts for sale" on this site, and craigslist, for 17" dodge take-offs, may even have tires attached that you like, and may have tpms already...
firecat is offline   Reply With Quote
Old December 9th, 2011, 06:13 PM   #4
302flexj
302flexj's Avatar
you can switch the sensors from your old wheels or buy new ones, new ones run around 60-70ish. and you cant run smaller then a 17 on those trucks the brakes are to big
302flexj is offline   Reply With Quote
Page generated in 0.21005 seconds with 36 queries
