Blazer 4.3 No spark No start - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 3rd, 2011, 09:55 PM   #21
GREASYHANDS
GREASYHANDS's Avatar
You should check the wires from the ignition switch. If you or some one else can get a diagram it would help. There are 3 or 4 switched b+ wires from the switch. If one of them is no longer being "turned on" you may not be getting power to all engine management systems. Check under the steering column at the large rectangular connection.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old December 4th, 2011, 03:14 AM   #22
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Thanks for the help everyone, Greasy Ill check those wires at tomorrow, I have the 3000plus pages of GM shop manuals, so I should be able to find the connection.
BTW who ever points me in the right direction has a cold one waiting for them at Snofari!!!
Old December 4th, 2011, 04:28 PM   #23
BlzrNick
Built not bought
BlzrNick's Avatar
what year is your blazer? I will pull up a wire diagram for the ignitions switch for ya
BlzrNick is offline   Reply With Quote
Old December 4th, 2011, 04:40 PM   #24
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Its a 99. Thanks nick
Old December 4th, 2011, 11:51 PM   #25
tonkatruckon44s
tonkatruckon44s's Avatar
have you changed the ignition module advance can test them and coils
tonkatruckon44s is offline   Reply With Quote
Old December 5th, 2011, 12:53 AM   #26
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
^^ yep its been replaced twice and the coil has been changed 3 times too
Old December 5th, 2011, 01:49 AM   #27
boggin-machine
boggin-machine's Avatar
Did you try the relearn yet?
Old December 8th, 2011, 03:50 PM   #28
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Yeah I've tried it twice now.
Does anyone know where I can get a full engine wiring harness? Google isn't helping and zr2usa.com is down right now.
Old December 8th, 2011, 03:58 PM   #29
BlzrNick
Built not bought
BlzrNick's Avatar
Sorry about the ignition diagrams. i will post them tonight if you still need them. The problem with the engine harness on theses is that its not just a single harness the plugs into the pcm. Its all one harness that goes to the engine, trans, front diif, transfer case, o2 sensors along with going into the body. So if you are able to find an intact one. its going to be extremely pricey.
Did you ever test if you getting spark from the coil. It shouldn't be that hard to narrow it down to what the problem is. Let me know what schematics you need and i can post them. Its a lot cheaper than shotgunning new parts at it
Old December 8th, 2011, 04:22 PM   #30
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
If you could post the diagrams that would awesome! I would need anything that relates to starting the truck. Including the ignition column and security system.
Thanks for the heads up on the harness, I haven't been able to find anything close to a complete harness yet, most are just one or two connectors. I have also tested for spark out of the coil with no luck.
Old December 8th, 2011, 04:30 PM   #31
joescamaro67
joescamaro67's Avatar
I had one that someone had tapped a remote start into and messed up the connector at the coil try to lightly tug on the individual wires with it plugged into the coil.Its a long shot but you never know
joescamaro67 is offline   Reply With Quote
Old December 8th, 2011, 05:02 PM   #32
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
As far as I know there isn't a remote start on the truck. I've had all the connectors on and off and they seem to all I've continuity but it still wont start.
Old December 8th, 2011, 09:09 PM   #33
97jeepcherokee
i got the jeep thing
97jeepcherokee's Avatar
how strong is your crank signal? ive seen many problems with shimming these crnak sensors, you have to make your own shim......... i just started reading about this so im interested to hear what the back story is and did it all the sudden just stop running or was it an intermittent that became permenant???? looking for more clues, the more info the better, pm me or call me, (616)889 7477, id be willing to help with whatever i can, not sure where white lake is but im in the grand rapids/holland area
97jeepcherokee is offline   Reply With Quote
Old December 10th, 2011, 01:53 PM   #34
TJontherox
Mall Rated
TJontherox's Avatar
Send a message via Yahoo to TJontherox
Has this been resolved? I have no idea if this would work for you but, I had an older S10 and the oil pressure sending unit went out on it, it didn't register oil pressure, which wouldn't allow the engine to fire. Again, I have no idea if this is the case for your truck, just throwing out another idea.
TJontherox is offline   Reply With Quote
Old December 31st, 2011, 07:54 PM   #35
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Just curious if you ever got this fixed? And what was the culprit?
sbcrichie is offline   Reply With Quote
Old December 31st, 2011, 07:57 PM   #36
tw1st3d5
tw1st3d5's Avatar
Yep he fixed it alright....motor and harness swap to a known running one.
Old January 1st, 2012, 10:02 PM   #37
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
And another computer, not the greatest way to fix it but it worked. I'm going to start swapping around components to find out what caused it but I going to put my money on wiring. At 12 years old the old wiring was very brittle and stiff.
Page generated in 0.34421 seconds with 74 queries
