Blazer 4.3 No spark No start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 2nd, 2011, 08:41 AM   #1
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Default Blazer 4.3 No spark No start
Alright, as some of you know I've been chasing this problem for quite awhile now, and I still cant get it.
The entire ignition system has been replaced including the computer and CPS. I have found that I have 12v at the coil and a pulse. I checked the pulse with a led as shown in the link below. According to this site this suggests a bad coil which I have replaced with no luck. Is there anything else I should be looking for?
http://easyautodiagnostics.com/gm_mi...re_tests_5.php
Thanks in advance!
Old December 2nd, 2011, 08:39 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
did you replace the crank or the cam position sensor? CPS could stand for either to some people
Old December 2nd, 2011, 08:54 PM   #3
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Yeah I should of clarified that, I've replaced both.
Old December 2nd, 2011, 08:54 PM   #4
GREASYHANDS
GREASYHANDS's Avatar
Have you checked to see if the dist shaft is turning with the engine? I assume you know about the drive gear at the cam that wears.
I take it you dont have spark.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old December 2nd, 2011, 08:59 PM   #5
BIGDANE36
BUY MY TRUCK
BIGDANE36's Avatar
Originally Posted by greasyhands View Post
have you checked to see if the dist shaft is turning with the engine? I assume you know about the drive gear at the cam that wears.
x2
BIGDANE36 is offline   Reply With Quote
Old December 2nd, 2011, 09:36 PM   #6
BlzrNick
Built not bought
BlzrNick's Avatar
put a spark tester right on the wire coming from the coil to the cap. do you have spark there?
BlzrNick is offline   Reply With Quote
Old December 3rd, 2011, 12:48 AM   #7
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
It does turn, I have also checked that the timing chain hasn't jumped and the rotor points in the right direction when #1 is at TDC. Its was a new distributor this summer, however I haven't pulled it to check the gear but it feels tight.
I bought one of those today and checked for spark at the coil with no luck.
What should the gap be on the tester? The recommended gap for the tester is almost a whole inch!! I checked the gap against my roommates car and his had to be running before the spark would jump Should I make the gap smaller?
Old December 3rd, 2011, 03:34 AM   #8
bdd1469
bdd
bdd1469's Avatar
You dont have a remote start on it do you?If so,unhook it and see if it starts.I've thrown away several of those,and fixed a few no starts.
Old December 3rd, 2011, 04:43 AM   #9
snow-turtle
Selective Hearing
snow-turtle's Avatar
so it is turning over , just wont fire
snow-turtle is offline   Reply With Quote
Old December 3rd, 2011, 12:34 PM   #10
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Nope no remote start. The security light on the dash doesn't flash either. Could the factory security system still be causing issues?
Yeah, I'm pretty sure my starter hates me by now
Old December 3rd, 2011, 12:35 PM   #11
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Does anyone know of a how to link on disabling the factory security system.
Old December 3rd, 2011, 05:29 PM   #12
BlzrNick
Built not bought
BlzrNick's Avatar
ill see if i can find something on the gm service info site
Old December 3rd, 2011, 05:41 PM   #13
boggin-machine
boggin-machine's Avatar
if you want to re program the security system i can tell you how to do that.
hook up a battery charger. and leave it there even if the battery is strong you will need it on there.
turn the key on but dont try to start it. just bump it. leave the key in the run position for 11 minutes. turn the key off for 30 seconds. repeat this step 2 more times. after you have done that 3 times turn the key off for 30 seconds and try to start. it should fire. what im having you do is reprogram the computer to factory. it just had to do this the other day and it works perfect now.
Old December 3rd, 2011, 07:08 PM   #14
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
^^^Thank you, Ill give it a try right now
Old December 3rd, 2011, 07:11 PM   #15
boggin-machine
no worries man. let me know how it works out for you.
Old December 3rd, 2011, 08:06 PM   #16
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
No luck But I accidentally bumped the key back to the accessory position once so maybe that threw it off.
Old December 3rd, 2011, 08:30 PM   #17
boggin-machine
that will do it. i had to do it 2 times cause i did the same thing. i did it on a 99 as well. it was getting no spark and after doing this it allowed me to fire it up. i had no power to the fuel pump as well before i did this. the computer relearned its self and then i had full power to everything again.
id say try it again and it should work. just have to be careful with the key.
Old December 3rd, 2011, 08:33 PM   #18
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
See that's my problem I have fuel at the rail and the pump kicks on as normal with the key.
I'm not so sure that the security system is my problem after all.
Old December 3rd, 2011, 08:48 PM   #19
boggin-machine
i had a light come on in the dash. but i the blazer sill wasnt getting spark so i tried to reprogram it and it worked.
Old December 3rd, 2011, 09:02 PM   #20
Freak
Wheelin the HD
Freak's Avatar
some security systems just target fuel, others just ignition.
Page generated in 0.59793 seconds with 83 queries
