04 gmc troble code help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 2nd, 2011, 06:35 AM   #1
trailbuggy
Default 04 gmc troble code help
I have a 04 gmc serria with a 5.3. I got gas the other day and about 2 miles down the road got code 0171 bank 1 lean! notsure if the gas has an thing to do with it. But put dry gas in it , clean the MAF,looked for vacumm leaks sprayed carb cleaner around the intake and cleared the codes was good for one day now the same code 0171 and 0300 random misfire? Idles bad but drives fine! Should i rule out the gas? I am going to put more dry gas and change fuel filter today after work. any other thing to check?? thanks
trailbuggy is offline   Reply With Quote
Old December 3rd, 2011, 04:47 PM   #2
trailbuggy
think i got it fixed! bad o2 sensor
Old December 3rd, 2011, 05:07 PM   #3
joescamaro67
joescamaro67's Avatar
Sounds like a b1s1 oxygen sensor.
joescamaro67 is offline   Reply With Quote
Old December 3rd, 2011, 05:11 PM   #4
buttercr125
I work out
buttercr125's Avatar
Sounds like the intake gasket is leaking. I know you said you checked it but you need to have a scanner hooked to it and watch your O2 readings and the LT and ST fuel trims when you spray it with carb cleaner.
Oh and your not looking for a vacuum leak, your looking for an air leak. Vacuum is not escaping out, air is forcing its way in.
Page generated in 0.15061 seconds with 35 queries
