04 freestar not running - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 1st, 2011, 05:39 PM   #1
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
Default 04 freestar not running
well i had just a few moments to look at this then it got dark and dinner was done. anywho my neighbor had me look at it and ill go back over tommorow. they started car this morning and went in. the car died and would not start.it does nothing when i try and crank it, no starter crank no relay click nothing. i jumped starter and it cranks. checked pcm as they are noted for water getting into them. dry as a bone and dealer had sealed it up from previous repair. can anyone get me a wiring diagram for this turn with pin call outs for the pcm? checked all cables and what not sadily it appears to be nothing easy
Old December 1st, 2011, 05:42 PM   #2
frdboy
frdboy's Avatar
4.2 or 3.9?
Old December 1st, 2011, 06:10 PM   #3
unclebeaner
i was told a 4.2
Old December 6th, 2011, 02:54 AM   #4
90Notch306
90Notch306's Avatar
Did you check if the ignition switch is sending power to the relay?
90Notch306 is offline   Reply With Quote
Page generated in 0.23269 seconds with 35 queries
