Dana 50 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 1st, 2011, 02:49 AM   #1
cushion101990
cushion101990's Avatar
Default Dana 50
Whats the deal with the 50s from the superduty? Not the ttb.... I kno the ring gear is smaller and the shafts are only 30 spline. but how mu?h weaker are they than a stock 60 How much stronger are they than a stock 44?
cushion101990 is offline   Reply With Quote
Old December 1st, 2011, 07:55 AM   #2
Elvis13
From my understanding the main difference was the 9" ring gear. Other than that my assumption was equal strength.
Old December 1st, 2011, 09:43 AM   #3
cushion101990
Are u unit bearings weaker than a older 60 with individually bearings
Old December 1st, 2011, 10:49 AM   #4
Elvis13
If you are comparing old 60's to the new 50's and 60's then that is a completely different question. That has nothing to do with the difference between the 50 and the 60. I do not know which is stronger.
Old December 1st, 2011, 07:48 PM   #5
littletrucker
I'd hit that
littletrucker's Avatar
Unit bearings are probably just as strong as a tapered roller bearing.. But most unit bearings are designed to run rims with offset that pull the tires in, and tapered roller bearings generally can run a rim with less backspacing with less problems.. Run a rim with Small backspacing on unit bearings and you are probably gonna eat them up.. NOT because they are weak, but because you are loading the bearing in a manner it wasnt designed for.
Ive really never seen problems with bearings, a lot of other things are gonna go before the bearings..
Old December 2nd, 2011, 03:04 PM   #6
cushion101990
The reason I ask is because I have a f250 with the v10 and am picking up a set of axles with the 4.30 gears in them to under the superduty. Since I got the stock axle that are 373 gears I thought about putting them under the ranger... Whats your guys opinion on how well that 50 would hold up to 40s and 513s?
Old December 2nd, 2011, 03:08 PM   #7
Elvis13
What year F250? IIRC '04+ should be a Dana 60. From my knowledge there were only 50's put in from 99 to 03 in all 250's and 350's, unless they were duallies, duallies got the 60's.
Old December 2nd, 2011, 03:09 PM   #8
cushion101990
Ya I have a 01 its a 50
Old December 2nd, 2011, 10:11 PM   #9
littletrucker
I'd hit that
About the only diffrebce I could see (besides the smaller ring gear etc) on the 50-60 is that the 50 axle shafts neck down to 1.3 inches next to the splines in the diff and the 60 stays at 1.5
Old December 3rd, 2011, 12:26 AM   #10
cushion101990
What size is a dana 44 chromo shaft? Thats what I got no and havent broke one
Page generated in 0.73406 seconds with 53 queries
