2003 7.3 aftermarket parts ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 30th, 2011, 04:59 PM   #1
warriorwynn
warriorwynn's Avatar
Default 2003 7.3 aftermarket parts ?
i have a 2003 7.3 f250. Just bought a wicked wheel and a intake heater delete plug. just wondering if anyone has done this to there truck and if it works. looking at adding a boost foiler and a new waste gate from dieselsite too. just wondering if anyone has any of these things and pros and cons
warriorwynn is offline   Reply With Quote
Old December 1st, 2011, 07:31 AM   #2
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
In my opinion your not going to gain alot of power with those parts. For a 7.3, a good 4" Turbo back exhaust, free flowing air intake/filter and a good custom tuned chip (Tony Wildman is my choice for my truck) and some gauges are all that are needed. They really wake up the 7.3. (300hp 600ft-lb tq at the wheels)
After those mods, if you want more power look to spend many many thousands on injectors, Turbo, trans upgrade, rotating assembly parts, customized tuning...
I'm the man in White.
Old December 1st, 2011, 05:11 PM   #3
warriorwynn
I have a mbrp 4" turbo back, superchip, and s&b air intake, and gauges. My problem is when im towing my camper. its about 8000 lbs and when im running between 55- 70. its like my waste gate opens to early or i throw a code from overboost and my truck defuels. the wicked wheel is suppose to help the turbo on my year and if i put dieselsites wastegate and boost relief valve i can set the wastegate to boost at 25 which i have read is where you want to run a stock turbo and the boost valve will regulate my boost so the map only sees like 20 so it wont throw a code and defuel. So just trying to get an idea if anyone has done this and if it helped. thanks for the info.
Old December 1st, 2011, 05:36 PM   #4
frdboy
frdboy's Avatar
I have the Overboost Annihilator from ITP, works well. I would ditch the superchip and get a real tuner from DP, Wildman, Swamps...etc.
Old December 2nd, 2011, 07:52 AM   #5
kickstand
circling the drain
kickstand's Avatar
superchip sucks.
Old December 2nd, 2011, 03:32 PM   #6
warriorwynn
so then i have a superchip for sale
Old December 7th, 2011, 05:55 PM   #7
warriorwynn
what chip works the best with towing and fuel mileage
Old December 11th, 2011, 05:32 PM   #8
Goped_Rdr
8 Lug Thug
Goped_Rdr's Avatar
Send a message via AIM to Goped_Rdr
I would never modify any electrical part of a powerstroke, as far as the "resistor mod" sensors, etc.I see alot of trucks with problems that stem from those types of things. I recommend the Dp tuner, I had a edge, superchips, once you get a DP youll never look back. For starters Id get a nice intake setup, downpipe, DP tuner, and a transgo shiftkit (its the only one I like). Dp tuner also does a ALOT for the 4r100, better shift points, firmer lockup, etc. For turbo, you can run the housing off an E-series van, if you want to stay on the cheap side. Down the road id get a converter, (the stock 7.3 one sucks). Im running a dp tuner w/ 6 tunes, intake, exhaust,trans built, stage 2's,and 17* pump. Very happy with the setup and its still daily driver safe.
Goped_Rdr is offline   Reply With Quote
Page generated in 0.36372 seconds with 47 queries
