2000 GMC Sierra 3500 Reg Cab 8' Box - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 30th, 2011, 02:08 PM   #1
kmollanketo
Default 2000 GMC Sierra 3500 Reg Cab 8' Box
Asking $6750
-Regular cab-
-Long box-
-Classic body style tan-ish in color-
-Auto trans-
-350 V8-
-Manual windows and locks-
-Cruise control-
-Tilt wheel-
-Sliding rear window-
-Bed liner-
-Tow package-
-About 89k on the truck-
The body has some dents and surface rust (rust along the bottom typical of most Chevy's of these years, but there's no big rust holes, I replaced the cab corners but haven't quite "finished" them yet.) The driver's door has a crease at the bottom, it appears a previous owner swiped a post or something similar, but still opens and closes fine. Tires are about 50% with a little weatherchecking. Windshield has no cracks but it does have scratches like someone ran worn out wipers or they were dirty for a while.
As of 3/2010:
New front hub assemblies..
New pitman arm and alignment..
New coolant temp sender..
Exhaust donuts replaced..
Hose and fitting from heater core to intake replaced..
Rear axle fluid changed at about 74k..
Replaced mass air flow unit with a used one that works..
Fuel pressure was tested and read 50+psi..
4/18/2011 - New Bosch Platinum+2 plugs
6/11/2011 - New front rotors and pads at 86k, new one-person bleeders installed in front. New shoes installed in rear as well. Replaced both rear wheel cylinders and brake lines from splitter. Have old shoes still in good shape, could clean up and use again but I changed them due to the wheel cylinder leaking.
Contact 906-370-FOUR ONE TWO FIVE
Truck is located in HOUGHTON, MI
TOOL BOX NOT INCLUDED -------- Currently has everything needed to put on a Western Ultramount plow (not including a blade with this truck) which I will remove, or include with the truck for $7000 total. Which to buy all the wiring, mounts, and plow pockets you're looking at $1000+!!
The tires in the pictures aren't the same ones that are in the descricption.
KBB Values:
Excellent
$7,177
Very Good
$6,902
Good
$6,777
Fair
$6,152
kmollanketo is offline   Reply With Quote
Tags
chevy 4x4 gmc one ton
Page generated in 0.24953 seconds with 26 queries
