Best budget U joint - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 30th, 2011, 01:40 PM   #21
2fst4you
2fst4you's Avatar
Wadey my shafts are USA standard as well unless you ordered me the CJ ones
My stubs are yukon though
Old November 30th, 2011, 01:47 PM   #22
2fst4you
2fst4you's Avatar
Originally Posted by wadey View Post
They are greased the same way as all of the higher end joints. with individual zerks in the caps themselves, this way there inst a hollow passage way running through the joint. They seem like they were designed well.
Ok cool ill probably go with those then. Just wanted to make sure they didn't have the hollow passages weakening the joint.
Thanks Ill make sure to look into the warranty specifics on both the U joint and shafts.
Let me know what you find out
Old November 30th, 2011, 01:55 PM   #23
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Wow I need a coffee or something For some reason I though I saw Yukon in the cart, maybe it was your stubs that through me off. But I'm pretty sure I ordered the right ones, we'll find out tomorrow!!! Shafts are on the way
Old November 30th, 2011, 01:58 PM   #24
Complete Off Road
Complete Off Road's Avatar
Originally Posted by BigBlockBlazer View Post
This, most cromo shaft warranties are void if you don't use a like wise joint.
not the case with Yukon. They will warranty any broken Yukon 4340 axle. I can't say for sure about other chromo axle companies tho (not trying to dis on them...just saying I honestly don't know).
Complete Off Road is offline   Reply With Quote
Old November 30th, 2011, 02:22 PM   #25
2fst4you
2fst4you's Avatar
haha hopefully you got the right ones then! We will see soon enough. Awesome!
Old November 30th, 2011, 02:31 PM   #26
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
good info. for me.. I need a new joint for my d44....
RIP FULLSIZE4LIFE
Old November 30th, 2011, 02:52 PM   #27
SUPERIOR will consider warranty of front axles with broken u-joint ears, as long as the supplied Dana Spicer 5-760 u-joint or better* is used and u-joint is installed using the supplied full circle snap rings.
*Acceptable replacement u-joints are Dana Spicer 5-760X, CTM, Ballistic Joint & Longfield Super Joint
I would say if Superior considers a 5-760X strong enough, it's plenty strong enough for a Yukon
Old December 1st, 2011, 12:22 AM   #28
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Well 2fst4you and I ordered a set of the Alloys so we'll see how they work out
Old December 28th, 2011, 11:33 PM   #29
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Here's what I ordered, the Alloy Usa 11500.
Compared to a Spicer 5-760x
In this pic you can see that the Alloy is slightly thinner than the Spicer.
This picture shows how the Alloy joint has "trapped" needle bearings. The Alloy also has a smaller ID than the Spicer.
The Spicer has 28 needle bearings compared to the Alloy's 26 needle bearings.
I am surprised to see that the Alloy U joint has a narrower side profile along with a smaller ID in the cap and less needle bearings. However the Alloy U joint carries a 3 year warranty so they must have done something right.
Old December 28th, 2011, 11:48 PM   #30
IDIeselman
IDIeselman's Avatar
They have done well with marketing!
Thanks for the comparison.
Old December 29th, 2011, 12:51 AM   #31
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
I should of added "...I hope" to the end of that
Anyone know how to add the gl4x4 logo to the photos?
Old December 29th, 2011, 01:24 AM   #32
bigblockford79
Big Block Ranger
bigblockford79's Avatar
I believe that you have to host the photo on the server for the logo to be applied, not just a link to another server. (like photobucket)
Old December 29th, 2011, 08:54 AM   #33
I would consider the Spicer to be the better joint with one exception. I like the individual lube fittings.
What is the price difference?
Old December 29th, 2011, 10:21 AM   #34
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
The Alloy was $40 from 4Wheel Parts with free shipping, the Alloy also comes with a set of full circle clips. The Spicer was $35 plus tax from Unlimited Off Road, and only has the traditional half clips.
I found the average price for full circle clips to be $5 a set. So if you are running the U joint in an aftermarket set of shafts, the cost would be the same per U joint.
Old January 20th, 2012, 01:26 AM   #35
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Well....
Sorry for the phone pics,
I broke the U joint when I got stuck with only 3wd. I was stuck in a ditch and could only reverse, so I put it in 4low and gave it everything the truck had, while wiggling the front tires being sure not to go to full lock. As you can see joint still failed and took out the both shafts in the process However I'm not sure that a Spicer would have done any better given the situation.
Ill be calling Alloy tomorrow to see about the warranty. Ill be sure to post the response.
Old January 20th, 2012, 08:22 AM   #36
I've broke alot of shit in my old 44's and I always ran 760x's, I've spit alot of caps and destroyed alot of shafts, but never broke a trunion on a 760x.
Old January 20th, 2012, 12:04 PM   #37
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I wouldn't run anything but a spicer 5-760X
I beat on mine hard with the same moly shafts you have and 38's and didn't break anything. The only thing I didn't like about the spicer is the caps, they kept cracking and the seals are junk.
Old January 20th, 2012, 10:03 PM   #38
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Ill be running one 5-760x and one Alloy at Snofari, so that will be the final test. But I'm not happy so far with there performance to say the least...
Alloy will be warrantying the u joint, so there at least standing behind their product.
Old February 6th, 2012, 09:16 AM   #39
Jetson
Jetson's Avatar
What's roughly a good price to do it with a mechanic.. I think my driver side joints are going bad and want to estimate some pricing here.
Jetson is offline   Reply With Quote
Old February 6th, 2012, 09:29 AM   #40
SHARPMACHINE
F-U-CANCER!!!
Wow, thanks for sharing your ALLOY results. I think I will run the spicer 5-760x joints.
RIP FULLSIZE4LIFE
Page generated in 0.46245 seconds with 84 queries
