monster jeep 8.8 swap done - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 29th, 2011, 12:41 PM   #1
dmoney
tj on 36 iroks
dmoney's Avatar
Location: fremont michigan about hour north of grand rapids
Default monster jeep 8.8 swap done
ive had this jeep for 4 years its been thourgh tons of shit i rolled it at 45mph yes 45mph and drove it to work the next day i still drive it but its more of a toy now.......i bought it 4 years ago for 1500 bux with 2 inch budget lift and a blowin transmission......2.5 ax5 231 sye.. heres the pics they speak more then words stock axles 36 iroks never broke a shaft ever and ive been wheelin jeeps for 7 years there will be pics of my other jeeps randomly most of them are now sold that isnt the newest pic of my tj...im ready to start my winter project on the jeep...ive got an 8.8 ls 4.10 rear axle my spider gears r pretty torn up in my rear end...ive got some xj leaf springs in my garage...ne good cheap ways of keeping the rear seat and put a tank in the back?(im a poor school bus driver and 23 years old) how hard is the propane swap....also ive got 21 inches of belly clearance with my custom skid plate...
dmoney is offline   Reply With Quote
Old November 29th, 2011, 12:46 PM   #2
JohnL
Go until it breaks.
JohnL's Avatar
Send a message via AIM to JohnL
2.5L, stock axles and 36" Irok's? Did I actually read that right? Holy crap, I thought my 4.3 on 35's was a dog.
Good luck with the build. It will seem like a whole new rig when it is done.
JohnL is offline   Reply With Quote
Old November 29th, 2011, 12:53 PM   #3
4Bangler
Jackstand Wheeler
4Bangler's Avatar
Originally Posted by dmoney View Post
...how hard is the propane swap....
Not as hard as it is dumb if you're already running multi port fuel injection on the 2.5.
Old November 29th, 2011, 12:59 PM   #4
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Where is the monster Jeep, or did I miss something?
BigBlockBlazer is online now   Reply With Quote
Old November 29th, 2011, 01:23 PM   #5
dmoney
tj on 36 iroks
dmoney's Avatar
i have to resize all my pics not happy
Old November 29th, 2011, 01:30 PM   #6
dmoney
tj on 36 iroks
dmoney's Avatar
i can drive this down the highway......just dont use 5th gear...srry bout the let down (monster jeep) thats what we call it with all the other jeeps around here.....does ne one else have problems with the tcase staying in 4lo when i did the sye i replaced one of the shifter fork bushings and its never been the same... the 4lo i have to hold in....
Old November 29th, 2011, 02:04 PM   #7
BigBlockBlazer
Axle breakin' 101
Sorry, this was my idea of a monster. My old trial rig next to a Jeep with 5" lift and 37's.
Old November 29th, 2011, 02:35 PM   #8
I've seen lots of monster jeeps but none as monstrous as the OP's.
Old November 29th, 2011, 02:37 PM   #9
I suck cocks. Lots of them.
locally famous
i was also disappointed it wasnt a monster, but i kept my bdmt out of his thread.
Old November 29th, 2011, 07:48 PM   #10
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
I ran a 2.5 with a auto and 38s with 5.13s and it was not too bad, Nice to see a semi local guy with a jeep
Old November 29th, 2011, 08:52 PM   #11
kickstand
circling the drain
kickstand's Avatar
You need to climb under your monstrous jeep with a 10mm wrench and adjust the linkage on your t-case, or get a t-case linkage drop bracket.
Old November 29th, 2011, 08:56 PM   #12
BluRubi
I think mine was a 13mm but I'm with him...I had the same problem after my t-case lift with the drop bracket.
BluRubi is offline   Reply With Quote
Old November 29th, 2011, 09:17 PM   #13
dmoney
tj on 36 iroks
dmoney's Avatar
Humm my tcase never went down only up maybe half an inch with my custom crossmember, the 4lo some how goes to far into 4lo... Im not just some jackass I build fix and wrench on all my own shit...i just feels like its spring loaded and pops out ive adjusted the linkage before & it didnt make much different and sometimes it hard to get into 4low....ive taking the linkage off before and put it 4 low manually and it popped out after I shifted from 1st to reverse.....i may pull the tcase for an inspection this winter
Old November 29th, 2011, 09:19 PM   #14
dmoney
tj on 36 iroks
dmoney's Avatar
Isnt there a detent ball to help it hold into 4 wheel
Old November 29th, 2011, 09:31 PM   #15
Fullsize4life
Kicking Cancers ASS
If it feels like a spring popping it out then it is out of ajustment.
Old November 30th, 2011, 07:38 AM   #16
kickstand
circling the drain
kickstand's Avatar
I could be wrong on the bolt size, in fact, I am almost 100% certain that I am wrong and you are correct.
who said anything about which direction you moved it? You moved it, it needs to be adjusted......jackass.
Of course depending on how long you left it popping out of 4-lo you may have done other damage as well and simply adjusting it may not fix it any longer.
this.
Old December 2nd, 2011, 07:50 PM   #17
dmoney
tj on 36 iroks
dmoney's Avatar
Default haha
well i used the jeep today winched out my buddy who was stuck in a 2 wheel drive ford......but yesterday i took out my transfer case outta of my 99 suburban (246) tow rig the rear tailshaft bearing only had 3 of the 6 balls left in it and the plastic inner race had fallin out, anyone who has ne doubt about tearing their t cases apart with ne mechanical experience, its not that hard....IMO.... hopefully ill be able to work on the jeep over christmas break i think im going to build a homebrew bumper i got a cheap bender and a bunch of tube left from my cross member, my bender wont make a nice 45 it kinks it, but i do want a pre runner bar, so i think im going to make one like this ^ ne one got pics of what you got?
if i put some gussets in the corners......i will be cutting the hood down sometimes tooo because my tube fenders are my bump stops? ne cut there own before i do mine did u you just cut to the first line?
Old December 2nd, 2011, 07:58 PM   #18
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
I have 1 3/4 and 1 1/4 dies for my bender. Bring me a six pack and I will bend you one if you bring the tube.
Old December 2nd, 2011, 08:34 PM   #19
Fullsize4life
Kicking Cancers ASS
Yes please dont do the pointed shit. It looks like ass IMO
Old December 3rd, 2011, 09:03 PM   #20
dmoney
tj on 36 iroks
dmoney's Avatar
Thanks for ur input I may hit you up chad....
Page generated in 0.56935 seconds with 83 queries
